6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
read up gentleman
Old Nov 13, 2011 | 08:01 PM
slowmans's Avatar
slowmans
read up gentleman
interesting read on Nitrate testing of the coolant.: CTS-3 Three-Way Antifreeze Specifications
Old Nov 13, 2011 | 08:24 PM
senix's Avatar
senix
that is a great link. Should be put in the tech folder.
Old Nov 14, 2011 | 01:10 PM
smotrs's Avatar
smotrs
Nice find slowman. Really good read.
No rep button on your post, oh well, your loss.
Old Nov 16, 2011 | 10:31 AM
Mud Doc's Avatar
Mud Doc
Explain the need to get sample from petcock? Have had nitrites checked by Ford dealer and at oil svc ctr--both of them dipped the stick into the degas bottle.
Joe
Old Nov 16, 2011 | 11:30 AM
pyro2nite's Avatar
pyro2nite
Good find. I keep seeing reference to a coolant filter. Wish the 6.4 came with one.
Old Nov 16, 2011 | 11:56 AM
senix's Avatar
senix
Joe
I do mine at the degas bottle as well.
Old Nov 16, 2011 | 02:22 PM
Mud Doc's Avatar
Mud Doc
I just bought a 6-test kit from Intl house and it also stated to get sample from petcock--maybe some setups have 'dead' fluid in the overflow container?
Joe
Old Nov 16, 2011 | 04:31 PM
bnmccoy's Avatar
bnmccoy
I actually bought a bottle of 50 strips directly from them some time back and noticed the difference with instructions regarding the petcock. Now most of bottle is expired so I need to buy more.....
Here is from Ford Service Manual:
"SECTION 303-03: Engine Cooling
NOTE: The coolant sample may be collected from the degas bottle only if the vehicle has been driven at least 1600 km (1000 miles) since the last time coolant was added, otherwise collect the coolant sample from the radiator draincock.
NOTE: The coolant sample must be between 10°C (50°F) and 54°C (130°F) when tested or inaccurate readings may result.
Collect a coolant sample from the degas bottle using the syringe or drain from the radiator draincock."
Bob
Old Nov 16, 2011 | 06:17 PM
slowmans's Avatar
slowmans
Joe
they are probably referring to the drain petcock on the radiator, its on the drivers side..under your bumper.
Old Nov 16, 2011 | 10:41 PM
Mud Doc's Avatar
Mud Doc
Well, since Ford says the degas bottle (bnmccoy) is ok if no AF added in last 1000 miles, should be ok. Don't care for trying to adjust the drain for a few drops. Glad to hear there wasn't a problem in the way it was done before.
Thanks.
Joe
Old Dec 8, 2012 | 09:12 PM
slowmans's Avatar
slowmans
Tested my coolant today truck is a 10' 350, 27,8xx miles, all is good, moly was 0, nitrates 1800 and the glycol was -50 to -60. I used the fleetguard test strips, only time I have ever added coolant is when I change my filters on my coolant filter, I use ford gold and distilled water at a 50/50 mix.
Old Dec 9, 2012 | 08:14 AM
wp6529's Avatar
wp6529
The degas bottle is not an overflow or recovery tank, it has constant circulation and is a perfectly valid testing point. Don't bother "taking a sample" get a long hemostat, clip the test strip on the end and just dunk it in the degas bottle.
Don't get the bottle of 50 strips unless you have a fleet to test, they will expire on you since you only need perhaps a half dozen per year even testing at every 5k oil change which is what I recommend since it's fast and the strips are cheap.
Old Dec 9, 2012 | 09:18 AM
StanleyZ's Avatar
StanleyZ
To get a SMALL package of strips (5 I think) call or fax numbers on the top of the Accu Strip page.
Old Dec 9, 2012 | 10:53 AM
RM2738's Avatar
RM2738
Bob
That's interesting... Makes it tough for me because dealer does all my maintenance. All fluids are at operating temps by the time I get there (200 DEGREES)
Old Dec 9, 2012 | 11:09 AM
slowmans's Avatar
slowmans
I bought a 4 pack at a local truck parts place for like 6 bucks..... I sampled mine after driving the truck up to temp and let it cool, took a sample and let it cool for another 15 minutes in the house. Air temp in the house was 67* F
ssunit1
Aug 19, 2016 08:51 PM
Gyrene4Life
6.7L Power Stroke Diesel
16
Apr 9, 2015 08:44 PM
petro1
Aug 24, 2011 05:17 PM
regidog
Apr 18, 2010 09:26 PM
NorCalBusa
Jul 15, 2009 02:16 PM
