Sponsored by: Kumho
Tire Pressure
Old Nov 13, 2011 | 03:08 PM
1L243's Avatar
1L243
Tire Pressure
1999 F250 Super Duty 2WD
I just had a set of Michelin MS/2 265 75 16 10 ply's put on my truck and am trying to work out the tire pressure.
The door says Front kpa 345/50 Rear kpa 414/60
Tires say 550/80psi
Tire installer put 80psi Rear and 55 psi Front
I normally run empty except when towing. 1300lbs hitch weight when towing.
Should I stick with the recommended tire pressure on the door? Or go by the side wall tire rating or what the tire installer used?
Old Nov 13, 2011 | 05:16 PM
blkF250HD's Avatar
blkF250HD
Always go by the door sticker. Pretty much all load range E tires have a max rating of 80 psi. You might be able to get away with dropping it a few psi for comfort and treadwear reasons- higher pressure can cause the center to wear sooner.
Old Nov 14, 2011 | 04:25 AM
Lazy K's Avatar
Lazy K
yes, go with door sticker pressures.
GatorBait1996
Jan 5, 2011 12:14 PM
rb8484
Apr 1, 2009 10:24 AM
bigredtruckmi
Oct 22, 2008 03:37 PM
christaylor
Jan 29, 2004 12:15 PM
WKMOTZU
Mar 12, 2003 09:20 AM
