So I bought a new radiator at Autozone and installed it in my '85 Bronco. The old radiator leaked a lot around the neck and seams. My question is this. The old radiator had an overflow tube coming from the fill neck, just one. The new radiator has two nipples coming off the filler neck. The radiator came with a rubber cap looking thing and since the book called for this radiator I just went with it and put the cap over the bottom nipple and hooked up my overflow tube to the upper nipple. I put on a new pressure release radiator cap on it and figured everything was fine.
Tody, while checking the oil, I noticed that I have anti-freeze leaking from the lower nipple that isn't hooked up to anything. I felt like there was good pressure behind it too. Did they give me the wrong radiator? I looked it up myself and it shows this one's right. Do I need to get a splitter and have two overflow tubes going into one that leads to the overflow tank?
Any ideas are appreciated.
Yeah, I ended up plugging it. I don't know why that radiator shows for my truck. Next time I'll pay more attention before I install it, let alone leave the store.
Hello, I too just changed te radiator on my Bronco. Mine is an 88 4.9L with manual tranny. Autozone showed the Spectra CU1454 as the replacement. It was different from the original as well. It also had the extra nipple at the radiator neck, it was at least twice as thick than the original, and has the auto tranny cooler connections. I think they just carry a "universal" radiator to fit all Broncos/F150s. The only problem I had was I need to modify the mounting tabs for the fan shroud.
I found the same problem with the shroud tabs. Of course, this was after I had put everything together. I wasn't about to take the radiator out or fiddle with the fan either so I just cut the shroud off with my sawzall. Before anyone freaks out, the shroud that was on it was really tore up and was going to need replacing anyway. Now that winter's just about here, I figure I don't need the shroud to channel the cold air.
I'll get a different shroud and install it when I do the water pump. Still, it is frustrating as hell when they list it specifically for your truck only to find it isn't a direct fit.
Do NOT trust the rubber caps that come with these radiators! That lower nipple is in the pressurized part of the radiator.
A better cap can be made by inserting a 3/8's bolt into a short piece of hose (Fuel, transmission or coolant) and a good hose clamp, then clamp onto the nipple with good another clamp. Do NOT use vacuum hose.
Granted, not very pretty-looking, but if the cheap rubber cap fails (Which it WILL do.), it could cost you angine.
Yep, Captradiator's right. That's how I found out. I put that cap on and it didn't take very long at all once the truck heated up to start spraying out from around that cap.
