trans shift rod c6
Old Nov 12, 2011 | 08:42 PM
miottimouse's Avatar
miottimouse
trans shift rod c6
my signal light cam broke the other day and figured i would pull it to put a better tilt columm and am having trouble re&reing the shifter rod that goes on the end of the columm mainly that plastic bushing i heat it up with a heat gun and that helps soften it up but man i have got into some weird positions trieing to reach the dam thing in behind the brake booster i thought i seen a rotundra tool to re&re the bushing/shift rod some where a few years ago am i right or just dreaming? and would any one know where new ones could be bought?
Old Nov 13, 2011 | 09:48 AM
mark a.'s Avatar
mark a.
Soak it with WD40 and use slip joint pliers on it. The WD40 will make it go right in.
Old Nov 13, 2011 | 01:22 PM
SwOkcOffRoader's Avatar
SwOkcOffRoader
X2 on the slip joint pliers. It's just a matter of getting the right angle.
72CC428
Nov 19, 2018 10:55 PM
zsir
Aug 23, 2012 11:47 AM
droppedf100
Jun 22, 2011 04:50 PM
Doon1
Oct 9, 2008 05:02 PM
Ratsmoker
Aug 15, 2002 08:34 PM
