Sponsored by: Real Truck
trailor light trouble
Old Mar 28, 2015 | 03:05 PM
Ford89mustang's Avatar
Ford89mustang
Originally Posted by ligito
If you have the auxiliary battery, check the state of charge and the connections.
I have the duels since its diesel and both are in great condition, brand new cable between them down to the starter.
I tried reading the voltage across fuse 6 and not getting anything. Not sure why that is.
Old Mar 28, 2015 | 03:21 PM
ligito's Avatar
ligito
A connection on one of them may be causing your issue.
Old Mar 28, 2015 | 04:51 PM
Ford89mustang
These are the underwood relays. No idea which group does what.
Old Mar 28, 2015 | 04:52 PM
Ford89mustang
The other wires are some custom wiring. I have slip tank pumps and exterior lighting etc, don't have factory up fitter switches so did all my own relays.
Old Apr 8, 2015 | 09:01 PM
Pipewrenchf350's Avatar
Pipewrenchf350
I don't mean to hijack this thread. But my 2002 f350 psd has no trailer running lights but every thing else is getting power. The fuse number 38 is good. I hear that there is a running light relay that is embedded relay in the single fuse block under the dash. Is this true ?
Old Apr 9, 2015 | 08:51 AM
speakerfritz's Avatar
speakerfritz
use a 7 way plug with LED's to verify your connector.
I troubleshooted a trailer weekend that just passed with the same problem....issues was grounds at each of the trailer lights. ran a star ground from each of the lights mounting bracket to the trailer connector ground and everythig worked fine.
other option would have been to weld the trailer mount brackets to the frame.
Bjbeard
Jul 16, 2018 05:10 PM
danlyst13
Electrical Systems/Wiring
Apr 8, 2008 12:16 AM
jlande
Apr 27, 2007 11:00 PM
Galen
May 28, 2006 08:58 AM
wat704
1997 - 2003 F150
Mar 1, 2005 10:16 PM
