Death Wobble
Old Nov 12, 2011 | 03:59 PM
brandonmartin's Avatar
brandonmartin
Death Wobble
I have a 1981 F100, 300-six, B/W 4-speed. I have replaced the rotors, calipers (& pads), all four tie-rods (& adjusters), steering box, wheel bearings, u-joints and had the tired balanced and the truck aligned. I STILL have a wobble in the front end at all speeds. The king pins are original, but seem tight. The rear axles do not appear to be bent and the wheels are not bent and the tires are good (says the guy that balanced them). Any other suggestions......... Please!!!!
Old Nov 12, 2011 | 05:58 PM
1983F1503004x4's Avatar
1983F1503004x4
You said tie rods, there's only one tie rod on mine and it's 4x4. Is yours 2wd?
Did you check the radius arms and radius arm bushings?
Has the truck ever been in a front end collision that might've bent the frame?
A wobble in the front end at ANY speed indicates that the wheels aren't tracking in the same grooves as the back wheels. This is common in motorcycles where the rear wheel nut isn't set so that the tire tracks the same as the front and it's common in Jeep vehicles too.
Whats the condition of the tires? Are they new? Do they have a lot of miles on them? If they do have a lot of miles on them, it could be flat spots on the rubber, but I doubt it with all the front end work you've put in.
Old Nov 12, 2011 | 06:09 PM
brandonmartin
New radius arm bushings. Bought the truck this way....... How do you tell if the frame is bent?
brandonmartin
Oh, and yes .....2wd
Old Nov 12, 2011 | 06:24 PM
bashby's Avatar
bashby
"Death wobble" is something that usually only happens once in a while, usually at higher speeds and only when you hit a bump just right. If you have a shake at all speeds all the time the most likely cause is a seperated tire or bent wheel. Jack it up and spin the wheels and watch the tread area from the front. you should be able to see any wobbles.
Old Nov 12, 2011 | 06:32 PM
1983F1503004x4
Bashby is right, the tire could've separated on the inside.
While you've got that thing up in the air checking the tires, check and see if they're feathered or if there are any flat spots worn onto the surface of the treads. If they're old tires and the alignment had been off for quite a while beforehand, that'd be common. You won't find any unevenly worn tires on a vehicle thats aligned though, so if your tires are new, don't worry about checking for uneven wear and feathering.
Also, while it's up in the air, start grabbing tie rods and stuff and seeing if anything has worked its way loose. You said you've more or less replaced the entire front end, so nothing should be out of place, but it won't hurt to look.
Old Nov 13, 2011 | 12:53 PM
81-F-150-Explorer's Avatar
81-F-150-Explorer
Also check the rivets holding the frame together in the front. If power steering leaked, it could "lube" the rivets and make it loose. Replace them with grade 8 bolts if loose.
Check the king pins by grabbing the tire with it on a rack and doing sideways and up and down motion with your hands. this will also check wheel bearings and spindles for looseness.
Other things that you did not mentioned that you should check:
1: worn or broke shocks or hangers
2: spindles
3: wheel bearings
4: warped brake pads or shoes
5: tires and wheels etc.. a tire balancing machine will tell you very quickly.
tyler.purrington
1978 - 1996 Big Bronco
Feb 5, 2014 03:35 PM
JJS72XLT
Dec 2, 2012 06:29 PM
Al Cowlings
Jan 5, 2011 12:18 AM
SuperKram
Aug 6, 2008 03:30 PM
Jeepincj7
Feb 20, 2003 07:47 PM
