87 Bronco walking all over road
twin I beam
I have heard of this problem with twin I-beams. They are susceptible to damage when either pulling or being pulled by the front part of the vehicle. The problem can be more noticeable when you put oversized tires and wheels on it. Check for frame damage near the twin I-beam mounts. A good front end shop will be able to pin point the damage and repair it. You might check forums for repairs to twin I-beams. The weakness can also be improved with welding of additional strengthening members. Hope this helps.
Ok, I don't think anyone has made clear just how many wear-points there are in the TTB Dana 44 front axle in this thread. ALL are suspect when dealing with "wander" in these trucks.
2 upper ball-joints
2 lower ball-joints
2 axle pivot bushings (inboard ends of the TTB axle halves)
2 radius arm bushings (aft of the axle between frame mount and radius arm)
2 or 4 shock absorber bushings (depending upon whether you have the auxiliary front shocks or not)
2 sway bar end links (if equipped with 2 bushings per link)
2 sway bar bushings (one on each frame rail)
2 outer tie-rod ends w/ bushings (outboard at each steering knuckle)
2 inner tie-rod ends w/ bushings (one attached to pitman arm, one attached to mid-point of previous inner tie-rod)
Wheel bearings were already mentioned but they are just as critical.
The driver's side axle pivot bushing mounts to passenger frame rail and vice-versa. These bushings are the most frequently overlooked and most frequently the culprit since they are the point of attachment for the axle that prevents lateral movement of the axle left-to-right under the truck. The radius arms and bushings prevent movement fore and aft.
2 upper ball-joints
2 lower ball-joints
If someone wanted to "rebuild" their TTB front end, would it be best to entirely remove it from the vehicle? Or should it be done in place?
To the same end, I would suggest performing the work with the front half of the truck well supported from the ground since it is helpful to remove both front wheels for easy access from multiple angles.
caesarnapolitano
12-14-2005 08:53 PM
