Sponsored by: Real Truck
Spare tire-lowering key
Old Nov 12, 2011 | 02:51 PM
Movingsolution's Avatar
Movingsolution
Bought my 2008 F-250 used and went to change the spare to realize that they didn't include the key that goes on the end of the tire-iron that allows you to lower the tire. Any way to get a hold of this with out spending the ~$100 on the whole jack assembly?
Thanks - Mark
Old Nov 12, 2011 | 03:22 PM
dchamberlain's Avatar
dchamberlain
If you can get your arms up around the spare to the winch, push the plastic guide tube (that guides the jack shaft) out of the way and pull the key end off of the winch. Then the normal jack end of the jack shaft will go in and turn the crank.
Then, at that point, if you really want a key you can go to Ford and they will be able to get you the right one easily. For a 2008, you can go to Ford and they might be able to look the key up for you and sell you one. I don't know how expensive they are, though.
Old Nov 12, 2011 | 03:27 PM
the beast 1's Avatar
the beast 1
I have a 01 and have the same situation. Was told by the dealer either cut the cable that holds it up or get a bar up on the lock and try to knock it off the end. Have not tried it yet.
Old Nov 12, 2011 | 05:29 PM
spinella's Avatar
spinella
dont cut the cable its fairly easy to remove the lock. like said in the above post, remove the plastic tube and you can pry out the lock. behind it is a hole that your jack tool fits into.
Old Nov 12, 2011 | 08:30 PM
A/Ox4's Avatar
A/Ox4
9 ECHO 1
All you need is a 9/16" socket on extensions. That will grab the lock and lower it just like the key.
Old Nov 12, 2011 | 09:39 PM
kd0axs's Avatar
kd0axs
I found that solution in a thread in one of the F-150 sections.
I took a 9/16 socket with a long extension and pounded the socket onto the lock. Then you can lower the tire.
Once the tire is down, go underneath and remove the plastic tube that goes from the bumper to the spare tire winch. It just turns about 1/4 turn and then pulls out. Then use a screwdriver and a hammer to pop the spare tire lock out, it's just held in place by a little spring washer. Replace the plastic tube and now you can raise and lower the tire with your jack handle.
Old Nov 12, 2011 | 10:53 PM
Movingsolution
Thanks much - will try this. Figured try not paying 100$ when I'm already strapped for cash from buying too many things for my truck =].
Old Nov 13, 2011 | 12:41 AM
3cv's Avatar
3cv
Did the socket trick, and yes, you pound it good and you can just lower it with the ratchet and pop off the keyed part.
Potlicker David
21
Mar 23, 2016 12:18 AM
Piffery1
1997 - 2003 F150
Sep 14, 2013 07:04 AM
ostrx250
Apr 27, 2013 08:34 AM
ascheperle
Apr 18, 2010 12:44 PM
indebt
13
Feb 18, 2009 02:40 PM
