quick 4x4 hub question
2000 f350 4x4 i know my u axle u joint is toast its real loose now my question is when i grab it and shake it the joint is loose and I'm getting play loose in hub side of the axle where it gos in the hub is that a indication of a bad hub or just u joint??
There is a little movement, Guzzles site may help
Welcome to guzzle's 4x4 Needle Bearing Maintenance Web Page
This may help also.
https://www.ford-trucks.com/forums/3...ll-joints.html
This may help also.
N.E.W.
Oct 24, 2010 03:56 AM
