I am finally figuring out AE and doing some stuff with it.
I was a little mad at first because i could not figure out why it would not save so i could look at it on my computer.
Followed the link you guys posted and had excel open it. Then i was able to see what was saved.
I did an idle test and a wot test. My pressure at idle is about 485 @ 697 rpm and jumps to 2200 as i sep in to it. Then falls to 1492 @ 3540 rpm's
This is parked and not under load..
Is this normal being parked and not under load ?
while driving my truck, it kinda feels like it tops and falls off a little at about 28 to 3k rpm's
^^^ What he said. On the initial throttle pulse, the engine sees load, but while in park and just revving the engine, there's really no load on the engine and the pressure drops accordingly.
