left key on
Old Nov 11, 2011 | 03:35 PM
rmalottwtes30's Avatar
rmalottwtes30
left key on
I left my key on my truck for about an hour. Came back to it and tried to start it and got nothing. My glow plugs glow but there is not even any cranking happening. Where should I look? Fuses, starter? Starter solenoid?
Old Nov 11, 2011 | 03:46 PM
tjc transport's Avatar
tjc transport
i ain't rite
check the batteries.
91dirtydiesel's Avatar
91dirtydiesel
dead batteries?
edit..darn you beat me lol
Lazy K's Avatar
Lazy K
I think I would try jumping the two big terminals on the fender mounted starter relay, if it then starts you need to investigate further. If it does not run the starter, then I would either charge the batteries or connect heavy duty jumper cables to it from another vehicle and try again.
Old Nov 11, 2011 | 03:53 PM
FORDF250HDXLT's Avatar
FORDF250HDXLT
you just unhooked your trans computer as shown in the other thread.
she won't be starting without the MLPS/neutral safety switch reading that she's in park.
Old Nov 11, 2011 | 03:56 PM
rmalottwtes30
It started jumping over the fender mounted solenoid, but will not crank via the key. ignition switch or solenoid?
Oh I got big news read in a few minutes on my transmission problem.
Scratcher's Avatar
Scratcher
Your batteries are dead.Or at least don't have enough juice to crank
Old Nov 11, 2011 | 04:01 PM
rmalottwtes30
Read my last post.
Old Nov 11, 2011 | 04:42 PM
tjc transport
i ain't rite
have someone turn the key, and check for power on the small wire at the solenoid.
if you have power at the solenoid, the solenoid is bad. if no power to the solenoid, then you need to backtrack to the neutral safety switch and then to the ignition switch.
Singing River Farm
18
Jan 25, 2014 03:51 PM
DWhiteyF250
15
Jul 25, 2012 11:59 PM
bburrito
Sep 18, 2011 01:13 AM
4EXTRDR
16
Jul 3, 2011 05:22 PM
onereelbigfishy
Jun 6, 2007 11:31 PM
