Sucessful Plug Change
Old Oct 28, 2012 | 11:42 PM
  #61
PSWP's Avatar
PSWP
Originally Posted by Whutakut Mk
Peace is sea foam safe to use on 04 f150 ? Thinking bout using it. I usually use Lucas " tune up in a bottle " advice please.
I have never tried the Lucas stuff. Seafoam is fine to use. Not sure how many miles are on your truck. Follow what I did in Post #1 and you should not have a problem. The engine should be at operating temp so all the components are at the same temp. Just letting it sit at an idle for a few min before you change them does not cut it. Have all your tools ready to go so you can start pulling the plugs out as soon as you pull the truck in the garage. A helpful tool for the removal process is a 6 to 8 inch section of old air compressor hose to help with pulling the plugs out of the head after they are loose. It also helps with putting the new plugs in and getting the threads started. The end of the plug should fit snug inside the tubing. This makes getting the back plugs started much easier. Good luck
barr993
2004 - 2008 F150
Jan 30, 2016 12:53 PM
Mcrafty1
Modular V8 (4.6L, 5.4L)
Oct 25, 2014 01:20 PM
boi_hawks
Modular V10 (6.8l)
Jul 3, 2013 06:41 AM
Field Scout
2004 - 2008 F150
Apr 22, 2008 08:58 PM
one5150fisher
2004 - 2008 F150
19
Feb 8, 2007 07:08 PM
