Sucessful Plug Change
Old Nov 13, 2011 | 11:56 AM
ChrisCarter's Avatar
ChrisCarter
There is a youtube video a guy posted up on another forum if I could find it I'd give you the link. He shows you how to do it with an impact, removes all 8, even the back. The back isn't bad with the right tools, besides my impact is fairly small.
Old Nov 13, 2011 | 12:00 PM
ChrisCarter
SPARK PLUG REMOVAL FROM AN 05 F150 5.4 3 VALVE USING A 3/8th IMPACT - YouTube
Old Nov 13, 2011 | 12:05 PM
ChrisCarter
05 F150 5.4 SPARK PLUG REMOVAL PART DUEX - YouTube
Old Nov 13, 2011 | 12:58 PM
Jim Allen's Avatar
Jim Allen
Thanks. Very interesting. I'd still wonder whether the the plugs on this or any other engine would have come out the other way. Doubting Thomas that I am, I'd do one by alternatively doing on the regularly and another with the impact and collect more data. No matter what, the impact sure saves a lot of exercise and if the odds are equal as to breakage, why not make it as easy as possible!
Old Nov 13, 2011 | 02:58 PM
ChrisCarter
Other then my word I can't give you documented proof.
The guy who did my phasers told me about it, and I tried it on a buddies one day in his garage, he had 110k on his, none broke. The impact vibrates enough of the carbon off before it comes out. I am not sure of the exact science behind it, but my guess is it doesn't get time to break, or else its the vibration.
Old Nov 13, 2011 | 03:35 PM
elrodalonzo's Avatar
elrodalonzo
I've had bolts as I'm sure many of us have that are real bears to get out and when you put the impact on them it's like wow that was really easy why didn't I use that before! The design of the impact which has vibration and of course impact sometimes can be the difference between day and night. I do admire your ***** for using the impact on the spark plugs. I'm sorry to say I just can't get myself to do it. If you ruin the threads on an old rusty bolt you just put in a new one. Obviously it would be a nightmare if this happens to the threads in your head. Although I haven't read of anybody doing this yet so far nothing but positive results. Good luck to those brave souls who do it, but I've got to get alot more positive input before I put my impact on a plug. Just my 2 cents of course.
Old Nov 13, 2011 | 04:56 PM
Jim Allen's Avatar
Jim Allen
Not doubting your word, Chris, and I understand the potential behind it. It's just that a few people doing something and having success doesn't mean that if 100,000 people did it that 88,000 would be successful. Do a few hundred more with the same success.
Old Nov 13, 2011 | 06:53 PM
ChrisCarter
The guy in this area has done more then a hundred successfully. If you PM me I'd give you his number. Its either him or the dealership. We live in a town no bigger then 27k people, he works on diesels mainly. He was the only guy in this area reasonably besides (Indiana) that didn't want an arm an a leg for cam phasers, and in this area no one will touch a 5.4L 3V engine, not even the plugs portion of it, with the exception of the ford dealer on the strip. He does it cheap, and quick. He can usually do it with you sitting there. Guy is excellent at getting the plugs out and only uses the impact.
Old Nov 15, 2011 | 07:10 PM
mach1cj's Avatar
mach1cj
Indiana ?
heck, i'll drive there and have it done. lol
Old Nov 15, 2011 | 07:18 PM
ChrisCarter
Henderson, Kentucky. Right across the bridge from Evansville. Bo Jones is the guy's name. I can get you his number, hes cheap and guarantees no breaks but he has the tool should one ever break.
Old Nov 15, 2011 | 08:41 PM
elrodalonzo
You're saying Bo has done over a hundred trucks that have this problem? That would be over 800 plugs without ever breaking one! That doesn't seem possible when it's rare that somebody can get all 8 out using hand tools without breaking any. The odds on this seem pretty long to me. Maybe you should give Ford this guys number and they can put out a new TSB and recommend the impact wrench, it would make them look like geniuses. I'm sure they would send a tech out right away to put this problem to bed, it would do wonders for their reputation.
Old Nov 16, 2011 | 07:25 AM
Jim Allen's Avatar
Jim Allen
Well, I've expressed my doubt about this procedure even while hoping it's true. THis whole spark plug thing is a crap sandwich from Ford and Autolite and some techs are adding even more poo when they take advantage of the hysteria to make money. I would applaud anyone like Bo who will find a way to do it fairly and more cheaply. It's just hard, based on what I know, to accept that 800 plugs came out intact with this method. It's one of those times when I have to say "I reserve judgement" and hope nobody is insulted... because I intend no insult to anyone. It's kinda like asking whether I believe in aliens. Man, I just ain't seen 'em yet!
Old Nov 16, 2011 | 12:16 PM
  #28
ChrisCarter
Why would Ford take this guys advice? The mechanic at the dealership that told him about this does this anyway. Most dealerships have a certain way to do stuff. Ford makes a killing off this, because 9x out of 10 the plugs break. They charge you a additional half hour labor per broken plug, and make a killing...
Ford is not going to change the TSB. I am just telling you what works. Hes been changing plugs on these trucks for a bit. He did my cam phasers, lash adjusters for 850 bucks, I supplied the parts which was an 811 dollars total. Ford wanted 2600 to do all of what he did, which I had the tensioners replaced, and the VCT Solenoid sensors... He did this in two days. He works on Powerstrokes mainly for a living, but hes got a good reputation around these parts for the plug changes. Also on this forum it seems people are a bit freaked out about the whole method I am referring to, but on another F150 forum this method is not new, and several people from different states claim to use this same very method without issue.
Old Nov 16, 2011 | 12:49 PM
  #29
elrodalonzo
My intent certainly is not to insult anyone or even question their integrity. The purpose of these forums are to share information for the better of it's users. If this method works as good as you claim and everyone is entitled of course to their opinion I am glad to hear it. The theory is sound I personally would not do it and hope that someone who is inexperienced doesn't think this is the bomb and get themselves in over their heads. For most people I still think hand tools are less risky for this particular job. I don't want anybody to take offense but like to post my opinion so others can make their own judgement.
Old Nov 16, 2011 | 01:46 PM
  #30
ChrisCarter
I wouldn't want anyone to try this without the tools to remove the plugs should they break, or the know how to use said tools, either method listed.
This is a big job, it takes a lot of time. When I had my plugs done a cousin of mine who had the tools did them. He broke 7 out of 8 plugs, they had 133k on them. Someone who has never dealt with this before should try this, and I do know a guy who attempted changing his plugs and the ford dealership ended up with the truck, the tool was no good, they ended up removing the head to get the plug out, cost quiet a bit of money.
