Need help with air leak
Old Nov 10, 2011 | 07:43 PM
86sixbanger's Avatar
86sixbanger
I just got an 89 250 4x4 7.3 with a ZF 5 speed. It has an air leak problem while running on the rear tank. When running on the front tank it runs awesome, except for a possible problem with losing fuel prime from sitting overnight. The injection pump is pretty much brand new. So what I'm wondering is where in the fuel system, and at what should I be looking for my air leak at? I'm thinking somewhere close to the rear tank..?..Thanks in advance......
Old Nov 10, 2011 | 07:53 PM
dieself250's Avatar
dieself250
What is the truck doing? How much fuel is in the rear tank. It could be a broken pickup in the rear tank, a bad fitting between the tank and selector valve, or a week lift pump.
Old Nov 10, 2011 | 08:10 PM
86sixbanger
Rear tank is full. On the rear tank once in awhile it will sputter and then surge while driving, and even stall out and die sometimes
Old Nov 11, 2011 | 01:38 PM
starmilt's Avatar
starmilt
If it runs fine from the front tank, except for fuel leaking back overnight, you have two problems.
One will be somewhere from the fuel selector back to the back tank.
The bleeding back will be some where from the lift pump to the return lines. The return line o-rings being the most common.
Old Nov 12, 2011 | 12:42 AM
86sixbanger
For the rear tank problem, could it be the in tank pump, or would it not get any fuel if the pump was defective???
Old Nov 12, 2011 | 03:56 AM
tjc transport's Avatar
tjc transport
i ain't rite
no in tank pump on these trucks
Old Nov 12, 2011 | 10:36 AM
86sixbanger
Sweet thanks so it's gonna be a line somewhere in there, and then maybe later on down the road I could replace the lift pump with an electric one? thanks
Old Nov 12, 2011 | 03:58 PM
tjc transport
i ain't rite
yup.
the intank pick usually breaks at about the 1/4 full line and then starts sucking air
darryl97420
Dec 26, 2014 10:20 PM
Fungus232
Jul 6, 2012 11:57 AM
84 f250 6.9
Oct 21, 2009 09:09 AM
BlueHeavyD
Oct 11, 2005 07:12 PM
rancherman84
19
Jan 17, 2004 06:27 PM
