Quick ? - Getting To EBP and MAP
Old Nov 10, 2011 | 11:13 AM
tm0231009's Avatar
tm0231009
How do I get to the EBP sensor and tube as well as the MAP on an 06 6.0L bone stock?
Thanks guys.
Old Nov 10, 2011 | 01:04 PM
bpounds's Avatar
bpounds
The EBP was relocated sometime in '06. If you have an earlier truck, it will be on the end of a tube near the coolant thermostat housing. On a later truck it will be near the FICM. You can see mine in the pic below, right below the nearest corner of the FICM. On each style it will be on the end of a metal tube. Pulling the air filter box makes it easier to get to.
Maybe someone has a pic of the MAP. I believe it is firewall mounted, but not sure about that.
Old Nov 10, 2011 | 02:37 PM
tm0231009's Avatar
tm0231009
Thanks a lot. That is where this one is. The tube was pretty dirty on the inside, hoping this solves the turbo underboost code. But in case it doesn't can someone help me out on the MAP sensor too. Thanks again.
Old Nov 10, 2011 | 03:41 PM
amdriven2liv's Avatar
amdriven2liv
I'm hitting easy street
Top of hose in the picture. Yellow circle is the hose.
Old Nov 14, 2011 | 08:30 AM
tm0231009's Avatar
tm0231009
Thanks guys this was exactly what I was looking for. This is why I recommend this site to anyone with a blue oval. MAP Sensor and tube looked good, but the EBP Sensor and tube were almost clogged completely. Hope this cures the CEL.
lio45
15
May 14, 2017 01:35 PM
grassman2852
Jan 13, 2013 12:18 PM
Rusty Axlerod
Jul 29, 2012 12:37 PM
Pilot-Pj
Feb 28, 2010 09:25 PM
agg_bagg
20
Aug 3, 2009 04:09 PM
