Sponsored by: Real Truck
AC Compressor; Always On??????
Old Nov 10, 2011 | 08:19 AM
Vette43's Avatar
Vette43
I have a 2000 F350 4x4 with V10. I just noticed that the AC Compressor is on whenever the "vent" selector is not set to off. Even if I do not have it set to AC. I can have the vent selector to floor and the temp slider to all heat (full red) and the compressor runs.
Is that normal?
Old Nov 10, 2011 | 09:19 AM
akorcovelos's Avatar
akorcovelos
yeah, I asked the same thing when I got my truck. Pretty dumb if you ask me, not sure why they did that. I believe if its set to floor/dash vents setting the compressor turns off, but thats it.
someone needs to figure out how to install a manual over ride switch or something so it can be turned off on any setting, probably increase mpg a bit.
Old Nov 10, 2011 | 09:20 AM
dchamberlain's Avatar
dchamberlain
I've attached a PDF file with the air flow descriptions from the 2000 service manual. You'll notice that the A/C compressor is enabled in every position except Floor, Vent and OFF. When the compressor is enabled it should cycle normally.
File Type: pdf
Old Nov 10, 2011 | 09:32 AM
Vette43's Avatar
Vette43
Yep... Runs just as the manual describes. Thanks again to FTE for a quick answer!!!
Old Nov 10, 2011 | 09:35 AM
Bigpipes 35's Avatar
Bigpipes 35
I know it is supposed to run in the defrost position to take out the moisture in the air. I have heard of people unpluging the compresser during the winter months when air conditioning is not needed.
Old Nov 10, 2011 | 11:59 AM
rs4-380's Avatar
rs4-380
this is good to know, I hadn't really looked into it yet but I though my compressor was staying on when it shouldn't (now I know it's design that way).
Old Nov 10, 2011 | 10:24 PM
bunklash's Avatar
bunklash
You can add a switch to enable/disable the AC clutch. Place a single poll, single throw switch in line with the violet wire at the back of your control switch. Be sure to get a switch rated at at least 10 amps. I put a really light duty one in first and it didn't last very long, overheated and opened up.
Here's an old thread: https://www.ford-trucks.com/forums/9...ml#post8666544
Old Nov 10, 2011 | 11:27 PM
BigAlsPSD's Avatar
BigAlsPSD
That's easy either install a switch in the wires going to the clutch to turn it on/off, or simply unplug the clutch if you know you wont be using it.
The purpose of having it on should be to remove humidity.
EDIT: Little slow I guess...
Old Nov 11, 2011 | 08:02 AM
akorcovelos
so did you see any noticeable increase on mpg by disabling the compressor?
Old Nov 11, 2011 | 12:16 PM
mwsF250's Avatar
mwsF250
Any mpg increase would be pretty much unnoticeable on these trucks. Maybe 0.1 mpg at best in winter. The compressor cycles on and off depending on thermal load, and during the winter,the thermal load is pretty low!
walksLikeBear
1983 - 2012 Ranger & B-Series
Jul 25, 2015 02:24 PM
stimm32
Jun 17, 2012 10:16 AM
ckal704
Mar 8, 2010 05:52 AM
98blueexpedition
Dec 22, 2006 11:00 PM
Buggie
Sep 25, 2004 07:52 PM
