slight idle rumble
Edit: Replaced the plugs and wires today, and it still has the issue. Ideas? I have been told by a couple friends that this is normal and nothing to worry about, but I would like to get that confirmed/fix if I am able.
If the idle by the tach observation is solid there is no issue.
The PCM is constantly chasing the idle rpm and keeps correcting by modulating the IAC opening to keep the idle within +/- 50 rpm, as measured by the crank sensor reports back to the PCM.
yeah this is what is happening. The RPM stays exactly the same, but it feels like the idle is varying but when looking at the tach it doesn't change. I had a hunch that this was normal but just wanted to confirm. If I did decide to fix it, what would I look at?
The other guy who responded said to look at the torque converter, is this where to start? I'm not too worried about it since the 6 or 8 F150s I drove about 5 of them had the issue.
Even a carbed motor often does not idle perfect.
There are a lot of reasons for this.
The conditions for idle are not perfect everytime a cylinder is up to fire so the rotational torque will not be exactly the same resulting in a rotational torque difference.
The crank assembly weight, the converter assembly all act to smoothout (store inertia) the cylinder torque pulsations but some torque differences will still be present.
This is why the IAC is modulated to vary the air to 'counter' the rpm differences.
The OX senors look at the OX content and return a signal to vary the fuel injected in [the NEXT cylinder]to fire.. If there is any over or under correction, this will add to the differences in rotational torque as well.
But the overall corrections are very good in the design but still not absolutely perfect because there are to many small changes in conditions that can't be acounted for every revolution .
Then you have wear and changes in outside temperatures, fuel differences over time that the system tries to account for.
Unless there is a cylinder down on compression, a valve that does not seal etc, a missfire will be detected as a change in rotation time by the crank sensor for that cylinder when compaired to the average of the other 7 cylinders as stored in a software tables. This is a moving vairable value so the software can change the tables over the life of the motor to account for average wear overall and other factors.
I know it's a lot of info, but the system is designed to be very smart but still not perfect.
After all it's a full computer system controlling a big hunk of moving metal set in rubber mounts so it will move and not transmit to much vibration and noise to the chassis.
One could get into a lot of reasons the rotational torque will not stay the same for each revolutaion, so there is lot more to this yet.
Good luck.
