Rear end grind
Old Nov 9, 2011 | 08:31 PM
bakerbuilttracks's Avatar
bakerbuilttracks
Rear end grind
hey yall.
I got a 2000 f250 7.3 4door 4x4. i got the truck in 06 with 96k on it. I got 217k on her now. I love the truck we have had our moments but i take great care of her.
Recently was pulling my 50hp deere tractor. I notice that when i turn onto a street from a stop sounds like the rear end is grinding real bad. From a stop starting off going stright it seems ok. But if im at a stop sign turning left or right when i take off the rear end grinds. Deffently not normal. It has been going on for a while and need to get it taken care of.
I have neglected the rear end. Have only changet the fluid once in 100k
I read a similar post awhile back about changing the fluid and putting an additive into it tho cure it if im correct. Anyone have any advice or insight on the subject?
Old Nov 9, 2011 | 08:56 PM
4x4countryboy's Avatar
4x4countryboy
check and make sure all of your brake calipers and brake brackets are bolted correctly in place and tight.
I had a similiar problem last week, brake bracket bolt had come out and the caliper was rubbing on the inside of my wheel....I could be waaaayyy off but worth checking anyways?
Old Nov 9, 2011 | 09:27 PM
bakerbuilttracks
i will take a look but seems as if that were the case it would be a continuous prolbem, not just under load while turning but i could be wrong
Old Nov 9, 2011 | 10:11 PM
mueckster's Avatar
mueckster
Since you have to pull the cover to drain the differential, I'd go ahead and look inside. If all looks good, change the gear oil and add 2 oz of limited slip additive. Drive it, turning frequently in both directions, and keep adding 1 oz until the clutch pack chatter goes away. If you add too much right away, the clutches will slip more and defeat their purpose.
Old Nov 9, 2011 | 10:47 PM
indyF-350psd's Avatar
indyF-350psd
you can't fix stupid!
what about the bearings in the rear hubs?
Old Nov 9, 2011 | 11:51 PM
Bonanza35's Avatar
Bonanza35
I would all above. If you don't find it check axle bearing. i did a brake job on my dually and found one bad wheel bearing I didn't even know it was there. Know noise that I heard. Changed all bearing and races. About 140K at that time.
Chet
fxsmit9
1997 - 2003 F150
16
Mar 12, 2012 11:34 PM
rsyauto
May 1, 2010 12:16 PM
quisp-n-quake
Mar 5, 2008 05:09 PM
tow4show
Nov 16, 2006 10:37 AM
Studenut65
Apr 10, 2006 12:00 PM
