need help power windows
Old Nov 9, 2011 | 07:18 PM
hiredgun's Avatar
hiredgun
1984 F250 XL supercab
new window motor driver's side works great,
new motor passenger side don't work,
unbolted motor from door and plugged back in runs in up mode from passenger side but not down
does not run up or down from driver's side switch
with hot and ground from battery direct to motor runs both directions
I messed with it till it got dark
test light grounded, probe to each wire one at a time light works on both with switch
also just for grins i plugged the window switch into the door lock switch (yes same plug pattern) and it will lock and unlock doors....hair is cut too short to pull out any ideas to further test
ManicMike
May 19, 2013 08:33 AM
Bronco_Daddy
Apr 4, 2012 08:46 PM
EdJones
Sep 4, 2011 09:33 PM
mistakenID
Nov 7, 2005 08:19 AM
3vanman
Aerostar
Dec 21, 2003 04:55 PM
