Help with alternator wireing
Old Nov 9, 2011 | 10:50 AM
51chris's Avatar
51chris
I have a 92 with a 7.3 from a 89 I just bought I've been having troble with the alternator. It seems that some one has cut the white wire from the regulator and hooked it to direct power on the solanoid then they have cut the green and red wire and hooked it to direct power off the solinoid with a togle switch to turn it on and off then just left the other two ends cut? So with a multimeter and a test light I'm going to try to figure out what's going on. But if any one knows were that green wire is powered and what fuses and relays it goes through it would be a big help. I am going to do a 3g eventually but right now I need to get the truck running before the snow flys. And also there is a rather thick green wire hanging off my glow plug ignitor switch with a bolt threw it dose any one know were this hooks up thanks guys
Old Nov 9, 2011 | 10:52 AM
51chris's Avatar
51chris
Or if someone could just direct me to some good wireing diagrams for these trucks that would also be just awsom
Old Nov 9, 2011 | 11:22 AM
PLC7.3's Avatar
PLC7.3
Chris email me and I will forward some info......... my info will be for the 92/3 alternator. If your using the 89 I'm unsure if it is different........ what amperage is it 90 or 130.
Old Nov 9, 2011 | 11:44 AM
Dark Horse's Avatar
Dark Horse
Welcome to the IDI forum
here are several Diagrams for the glow plugs and alternators :
https://www.ford-trucks.com/forums/p...ictureid=76232
https://www.ford-trucks.com/forums/p...ictureid=70803
https://www.ford-trucks.com/forums/p...ictureid=70802
https://www.ford-trucks.com/forums/p...ictureid=84674
You will have to decide which alternator is on your truck
some times the hardest thing is to figure out what a PO did to it before you got it.
good luck
Old Nov 9, 2011 | 08:30 PM
51chris's Avatar
51chris
so after looking at some pics of the controller i have realised mine is missing a peace the metal squiggly thing and the stud to bolt it to so back to the parts store and as for the alternator its killing my two new batterys even if the switch is on or off so i will get to the bottom that next
IDI-Charlie
Electrical Systems/Wiring
Apr 2, 2014 10:24 PM
1972RedNeck
Aug 16, 2011 11:24 AM
todd jo
Dec 7, 2007 08:10 AM
cangim
Sep 7, 2005 04:10 PM
monkei
Feb 19, 2004 06:58 PM
