AC just quit
Old Nov 8, 2011 | 10:12 PM
f1504x4driver's Avatar
f1504x4driver
Proud Pirate
AC just quit
my AC just stopped working, no warning, no leaks. The Clutch will not engage. I have checked the fuses, and the switch and all seems to be normal. The clutch is not locked up either. I am at a loss. Any Ideas, I am thankful for any help.
thanks
Old Nov 8, 2011 | 10:33 PM
White 97 xlt's Avatar
White 97 xlt
Try bypassing the low pressure switch (jumper the plug) on the accumulator, if it runs then it is either a bad switch or it's low on refrigerant. If it runs don't keep running it, if it is low on refrigerant you can do damage to the system.
Old Nov 8, 2011 | 11:17 PM
rla2005's Avatar
rla2005
X2
The low pressure/clutch cycling switch is not immune to failure.
Old Nov 10, 2011 | 07:42 PM
f1504x4driver
Proud Pirate
Thanks guys, it was the switch. I replaced it when the clutch stopped but it still did not work. Turns out the new switch was bad as well. Runs like a top again and will freeze you out.
Old Nov 10, 2011 | 08:58 PM
White 97 xlt
Good deal,, glad it worked out for you!!!
Old Nov 10, 2011 | 10:08 PM
rla2005's Avatar
rla2005
Thanks for the feedback!
NetDoc2k
Electrical Systems/Wiring
Jun 15, 2012 09:23 AM
tshrager
Apr 9, 2012 08:13 PM
terrier
1997 - 2003 F150
Aug 29, 2009 07:43 PM
MikeD1980
1997 - 2003 F150
May 13, 2009 06:09 AM
jaja
1978 - 1996 Big Bronco
Jul 19, 2002 04:35 PM
