Posi re-gear
Old Nov 8, 2011 | 09:49 PM
Boba Fett's Avatar
Boba Fett
Posi re-gear
I am building up a low buck rear.... I got a new clutch set for and old 28 spline equalock from my 67 bronco and I am putting it into a 79 center with 28 spline axles. My question is if you can use 4.11 gears on that posi. Factory it had 3.50 gears. I remember there being different posi units for gears over a certain size or under a certain size.... So can i use the 4.11 gears on this posi?
Old Nov 9, 2011 | 07:38 AM
gfw1985's Avatar
gfw1985
Cranky Old Guy
Center chunk should be the same on all 9" rears. The front axle is where you run into problems. I swapped my 4:11's into a later model third member since my old one was busted.
Old Nov 9, 2011 | 09:01 AM
Boba Fett's Avatar
Boba Fett
Thanks gfw
JimsGT
Nov 1, 2012 01:18 AM
waynepriddy
1978 - 1996 Big Bronco
May 21, 2008 11:52 AM
Brnco85
Jan 9, 2005 11:19 PM
emoe
1997 - 2003 F150
Jan 5, 2005 10:29 AM
