Squealing Noise
Old Nov 8, 2011 | 07:32 PM
King7765's Avatar
King7765
Squealing Noise
Towing on the highway today and under hard load at around 65mph, 2400rpms, 10psi, 1100 degrees.
Hear a weird *** squealing noise. Backed off the throttle, it stopped and came back on with hard throttle.
Possible the turbo is hitting the housing?
Old Nov 8, 2011 | 08:42 PM
F350-6's Avatar
F350-6
It's possible. Pull the intake and inspect the wheel and housing for any signs of contact. Check the shaft for in and out play, or see if you have enough up/down or side to side play for the wheel to contact the housing.
Also try pulling the belt and inspecting all the pulleys to see if anything doesn't feel right. I've seen a worn water pump start to squeal as the impeller began to rub against the water pump housing and front cover.
Old Nov 9, 2011 | 03:36 AM
Chris56ford's Avatar
Chris56ford
lost
All the things above and also check the vacuum pump, they have a sealed bearing. They will squeal at higher RPMs when the bearing gets dry and starts going out.
Old Nov 9, 2011 | 07:18 AM
King7765's Avatar
King7765
Okay, thanks guys.
I'll check that stuff out today.
Old Nov 9, 2011 | 07:42 PM
lud04X's Avatar
lud04X
I had this happen and it turned out that the alternator pulley siezed up and the belt was going around it and squeeling. I needed a new alternator and pulley. Luckily I was able to walk to Napa from where I was stopped, lol.
strokersace
21
Dec 31, 2017 11:44 AM
The Terrible Blob
Sep 2, 2014 10:30 AM
One Sock
2004 - 2008 F150
Mar 8, 2014 08:37 PM
dieselaholic
Jun 20, 2010 05:24 PM
daddzwaterboy
Mar 9, 2004 10:38 AM
