No fuel?
Old Nov 8, 2011 | 12:00 PM
brcwelding's Avatar
brcwelding
No fuel?
What could be causing my 88 f250 351w to not be getting fuel. I hear the pumps kicking on when i turn the key. What else causes an engine to get no fuel?
Old Nov 8, 2011 | 12:15 PM
DiscardedFrog66's Avatar
DiscardedFrog66
Single tank or dual? Have you checked the fuel at the rail?
Old Nov 8, 2011 | 02:58 PM
brcwelding's Avatar
brcwelding
Its dual tank. How do i check the fuel at the rail?
Old Nov 8, 2011 | 03:07 PM
SCRebel's Avatar
SCRebel
On the fuel rail there is a fitting that looks like a air nipple for a tire. You can press the center and if there is pressure in the fuel rail it will spit out gas.
You can also get a fuel pressure regulator to check a see if you have a bad pump, clogged filter, or if the tank selector valve has went bad.
Old Nov 8, 2011 | 03:08 PM
cj06's Avatar
cj06
put a pressure gauge on it to check the fuel pressure !
Old Nov 8, 2011 | 06:26 PM
brcwelding's Avatar
brcwelding
Where do i hook up the fuel pressure gauge?
Old Nov 8, 2011 | 06:51 PM
73FOMO's Avatar
73FOMO
On the fuel injector rail. Looks like a tire valve. Gauge threads on there. Should be reading 30 - 35 psi at idle increasing to around 40 psi with throttle.
Old Nov 8, 2011 | 06:55 PM
rla2005's Avatar
rla2005
Driver side fuel rail, looks very similar to a tire valve stem. There may be a black cap on it.
Old Nov 8, 2011 | 07:34 PM
brcwelding's Avatar
brcwelding
Ok thanks guys. If i dont get pressure at the rail what could the issue be?
Old Nov 8, 2011 | 08:33 PM
SCRebel's Avatar
SCRebel
Clogged fuel filter, bad pump(s), bad selector valve or bad fuel pressure regulator.
rangerlugnut
May 22, 2017 12:38 AM
Big-Red-Lariat
Escape & Escape Hybrid
Mar 3, 2013 11:04 PM
91chevywt
Mar 4, 2011 04:48 PM
302 F-150
Aug 28, 2007 03:14 PM
muzz3256
Jul 20, 2003 08:27 AM
