Rear tank fills the front tank. Yes I know it's a "Fuel Delivery Module" But nobody has yet to give me a part number relevant to use to actually get this problem fixed.
You need to go by application, the pictures are sometimes just a representation of the actual part.
Bingo, because the trucks don't have 3 ports on the sending unit...Only 2; Send/return...
The 3rd one is on the gas tank its self, and is simply the line used to pull the vapors away to preven the tank from vaporlocking...Total different system...
Go to Rockauto.com, tyoe in the year, make, model, and engine...And it'll come up what they have in front/rear tanks...select what you need...and done...
I got these pictures from Rock Auto. Since there was only a couple of 3 port fuel pump units i figured these were it.
So the "Fuel Delivery Module" is a complete fuel pump package? If you look at the different fuel pumps listed there's a few different kinds for the different tanks. None of them say outright "for duel fuel tanks".
There are 5 different fuel pump modules for a 1993 F150 front tank (actually the correct term is "midship" tank)
There's variations by wheelbase, number of tubes, 2 or 4 wheel drive, and transmission type.
Do'h!...You're right.....Again, you simply type in what you have...lol
i bought a whole tank/pump combo from rockauto when my truck was leaking gas from the front tank into the back tank, and then leaking onto the floor. the whole rear tank came with the pump installed. all i had to do was take the old one out and put the new one in. no fooling around trying to get the new pump to seal onto the old tank. the price was very good too. put all the info for the truck on rockauto.com and they will send you the right part. the picture is generic.
