My friend you are in the right place!! If you got a problem with your 7.3 dis is da place to get your prob solved! Some mighty fine friendly and smart peeps here I tell ya!!
Im new at this forum stuff so I'm trying. Am I in the right place
You are now. I've moved your thread to the 1999 - 2003 7.3L Powerstroke Diesel forum. You'll get a wealth of outstanding information from these folks.....they're great.
Ok guys I really appreciate it. Hello ford People, I have a 2003 f350 7.3, it's been giving me some problems it will run fine and unexpectedly shut off it might cranck back or it mighty crank the next day. It is real unreliable right now. I have a scan tool and sometimes it will link up and sometimes it won't but in always will link if the check engin light is off. I did get to pull some codes. Hear they are, hope fully someone can tell me if one of them will make my truck act this way. Input turdine speed sensor a circuit, shift solenoid c, system voltage, icp failure / cct test.*
When it won't run my scan tool says waiting for vehicle to respond then it will say no response check plug, make sure ignition is on and stuff like that. When it will run it will always connect.
