My f350
Old 11-07-2011, 06:50 PM
BigAlsPSD's Avatar
BigAlsPSD
BigAlsPSD is offline
I would suggest you start a post in the 1999 - 2003 7.3L Power Stroke Diesel - Ford Truck Enthusiasts Forums we will get you figured out if you are patient and willing.
IPR is located on the rear of the HPOP. Here's a pic for reference.
Name:  Barry's Sensor Locations.jpg
Old 11-07-2011, 06:52 PM
powerstroke72's Avatar
powerstroke72
powerstroke72 is offline
Moved to the 1999 - 2003 7.3L Power Stroke Diesel forum.
Old 11-07-2011, 06:56 PM
CRosdahl's Avatar
CRosdahl
CRosdahl is offline
Im new at this forum stuff so I'm trying. Am I in the right place
Old 11-07-2011, 07:06 PM
Smokiesman's Avatar
Smokiesman
Smokiesman is offline
My friend you are in the right place!! If you got a problem with your 7.3 dis is da place to get your prob solved! Some mighty fine friendly and smart peeps here I tell ya!!
Smokie
Old 11-07-2011, 07:12 PM
powerstroke72
You are now. I've moved your thread to the 1999 - 2003 7.3L Powerstroke Diesel forum. You'll get a wealth of outstanding information from these folks.....they're great.
Old 11-07-2011, 07:38 PM
CRosdahl's Avatar
CRosdahl
CRosdahl is offline
Ok guys I really appreciate it. Hello ford People, I have a 2003 f350 7.3, it's been giving me some problems it will run fine and unexpectedly shut off it might cranck back or it mighty crank the next day. It is real unreliable right now. I have a scan tool and sometimes it will link up and sometimes it won't but in always will link if the check engin light is off. I did get to pull some codes. Hear they are, hope fully someone can tell me if one of them will make my truck act this way. Input turdine speed sensor a circuit, shift solenoid c, system voltage, icp failure / cct test.*
Old 11-07-2011, 07:59 PM
CRosdahl's Avatar
CRosdahl
CRosdahl is offline
One thing I left out when it won't start the wait to start light won't go out for a wile
Old 11-07-2011, 08:31 PM
BigAlsPSD's Avatar
BigAlsPSD
Thanks John
Is the vehicle acting up right now? If it won't start right now maybe you could get us some live data while cranking and we can analyze that data.
Old 11-07-2011, 08:33 PM
CRosdahl's Avatar
CRosdahl
CRosdahl is offline
Let me run out out and try it
Old 11-07-2011, 08:35 PM
CRosdahl's Avatar
CRosdahl
CRosdahl is offline
Yea it will run right now
Old 11-07-2011, 08:39 PM
CRosdahl's Avatar
CRosdahl
CRosdahl is offline
When it won't run my scan tool says waiting for vehicle to respond then it will say no response check plug, make sure ignition is on and stuff like that. When it will run it will always connect.
BigAlsPSD's Avatar
BigAlsPSD
Well that's good but not good to help see what is going on.
  #28
Old 11-07-2011, 08:40 PM
BigAlsPSD's Avatar
BigAlsPSD
Have you looked at the PCM relay? Or tried swapping it with the blower relay? There are also diodes that can fail.
  #29
Old 11-07-2011, 08:44 PM
CRosdahl's Avatar
CRosdahl
CRosdahl is offline
No I don't have a owners Manuel so I dont have a map of fuses or relays
  #30
Old 11-07-2011, 08:47 PM
BigAlsPSD's Avatar
BigAlsPSD
Quick Reply: My f350
