how to test the tps sensor?
Old Nov 6, 2011 | 08:14 PM
Midnite1987's Avatar
Midnite1987
ok i found the link to the ford fuel injection on testing the tps but i think im missing something....
can someone give a quick explanation on it?
do you test it with out the plug and measure the ohms as i open the throttle to see for smooth increase? where would it start and stop?
im assuming this is done with the truck off...
on the ford fuel injection it talks about volts... is that key on checking?
how do you get the idle reading? is it with the throttle closed? i would think that wouldnt be idle... or does it have to be running to check it....
i dont know why im having a hard time with this lol
Old Nov 6, 2011 | 09:09 PM
DRRXR's Avatar
DRRXR
Hope this gives you the edge you need
Key must be on
You should find what you need here
Ford Bronco And F-150 Links - EEC-IV; SELF TEST & Diagnostic Trouble Code (DTC), Overview, etc.
here is another---
Ford Fuel Injection » Throttle Position Sensor (TPS) this may be the one you have
and another
https://www.ford-trucks.com/forums/1...ltage-low.html
Hope that helps
Old Nov 6, 2011 | 10:34 PM
Midnite1987
yeah the ford fuel injected one is the one i have.
i dont know if its just me but i can't find a procedure to test it in those links....
Old Nov 6, 2011 | 10:41 PM
rla2005's Avatar
rla2005
The chart at the bottom of the page with the expected voltage values is not enough for you to determine if the TPS is bad?
markes12344
Dec 21, 2013 03:20 PM
Slomoe
Dec 12, 2013 06:06 PM
van1989
Aug 29, 2009 08:52 PM
milkman22
1983 - 2012 Ranger & B-Series
Apr 21, 2009 08:07 AM
ewellman
Aug 25, 2004 01:59 AM
