E-brake cable boots
Old Nov 6, 2011 | 11:10 AM
firstrider's Avatar
firstrider
E-brake cable boots
In the past yr. or so have acquired 3 sets of NOS e-brake cable boots . Has cooled off some here in S. Fla. so deided to slide under the 1ST-RIDE and install a set . The attaching pins were froze so a little heat solved that problem .Then some media blasting , primer and paint and once again ready to proceed .Slide the boot over the threaded end on the cable and up to the attaching bracket on the chassis and found the larger end was going to be real tight . Tried to pry it on with a varied assortment of tools with no progress . Looked at another set of boots only to find one set was larger on that end . Used this set with the help of a little silicone spray and it went right on .So this conclusion was finalized .All sets are PT# 01Y-2597 but the truck set is F15 and the car sets are F20 . So am glad the reprduction process has not started yet but now know what I have . Still kicking ideas around in my head as how to reproduce these .Am close to a final process . Now to find some peaceful , quality time to make the molds .See pics .
Old Nov 6, 2011 | 11:58 AM
firstrider's Avatar
firstrider
Tried to post pics 3x .Followed Ilya's instructions to a T downloading pics from album .. Am I doing something wrong or has something changed ?
Old Nov 6, 2011 | 12:22 PM
Jolly Roger Joe's Avatar
Jolly Roger Joe
Let me see if I can help with the pics. The pics have to have a URL in their location. So they must be uploaded to the internet somewhere, I use Photobucket. Once on the internet, while viewing the pic you want, right click and select "view image info", copy the URL which look be similar to this:
http://i285.photobucket.com/albums/l...4/DSCN1178.jpg
Then from your post, select the Insert Image icon above (looks like a mountain) and paste the copied URL over the highlighted "http://".
This is covered in Read First: 48/60 Forum Tips, Tricks, How To's!
HOW TO POST PICTURES
Old Nov 6, 2011 | 12:30 PM
Jolly Roger Joe
Wait a minute
I see you've been posting here long before me, so what I just told you, you probably already know. At times, I've had problems with the posting not work because of something wrong on the Internet, even though I repeat the correct process several times.
I had a posted video run correctly for a few minutes, then stop working for a few days, then start working correctly again.
So maybe I''ll just butt out quietly now and go away.
Old Nov 7, 2011 | 09:21 AM
firstrider's Avatar
firstrider
e-brake boot pics
At least a pic posted !!! Sorry for the small pics ,maybe enlarge to see .
filthy6
43
Nov 7, 2015 07:49 PM
lcgeek
Oct 15, 2015 07:56 PM
SteveBricks
S. California Chapter
Aug 6, 2011 08:37 PM
TransplantX
20
Aug 16, 2008 03:59 PM
kennedyford
30
Nov 5, 2006 12:21 PM
