oil pressure
Old Feb 12, 2010 | 08:20 PM
87f150stepside's Avatar
87f150stepside
oil pressure
hey guys i got a 351w that runs with normal oil pressure but when i stomp on it from a stop and then let off the oil pressure drops to nothing aand then comes back to normal. If anone knows whats wrong lemme know. Thanks
Old Feb 13, 2010 | 10:48 AM
andyman7931's Avatar
andyman7931
are you using the stock gauge to monitor pressure? you could have a faulty pressure sensor if so. I'd put an aftermarket gauge and then see what's going on.
Old Feb 13, 2010 | 11:10 AM
lew52's Avatar
lew52
Check the oil ...Lew
Old Feb 13, 2010 | 11:15 AM
quicklook2's Avatar
quicklook2
just don't stomp on it and then let off.
Old Feb 13, 2010 | 08:10 PM
mikebrawn1's Avatar
mikebrawn1
Check the gauge and sending unit first. If you still have the problem after that then I would look at the oil pump pickup screen being clogged. I just bought a 96 f150 for $600. It had the same problem. It would have oil pressure at idle but when you accelerated "briskly" it would drop to nothing and the lifters would start tapping. I pulled the pan and changed the pump and pickup and problem is gone and it runs great now. Can't beat a ford.
Old Feb 13, 2010 | 08:21 PM
BGilley's Avatar
BGilley
Although the engine is broke in use a good brand of oil like "castrol" after you find your problem.
