2002 f-250 v8 7.3l
2002 f-250 v8 7.3l
Couple weeks ago I had to replace my Camshaft sensor, as well as fuel filter. An i went ahead an replaced the glow plug solenoid. as well 2 new batteries.
The other night She died on the road. once again I lost power no acceleration.
An i got a crank but no turnover. So I had her towed.
SO now. I have replaced the Camshaft again. I replaced all mini fuses.
I unpluged the fuel bowl heater.
Still getting the crank but no turn over.. I also get a lil hiccup like it has something to do with fuel.
I'm getting fuel in the bowl if i put it to on. any ideas?
When you turn the key to on, the fuel pump should run @ 20 sec. Its located on the drivers frame under the door. With the drain valve open, you should get a stream of fuel from the drain under the truck.
There is a fuel pump off switch located in passenger foot well behind kick panel that may have tripped if you find the pump not running. Fuel pump is fuse #40.
How much fuel is in the tank? There is a pick-up "foot" on the bottom of the in-tank assy. that has been known to crack or come off so if the tank is too low it may not be able to suck the fuel up. If the tank is pretty full the screen in the mixing chamber on the fuel pick-up in the tank may be plugged.
