302 motor?
Old Nov 4, 2011 | 07:00 PM
trumsey07's Avatar
trumsey07
302 motor?
i recently installed a 302 from a 77 f150 into my 86 f150 and today i noticed that the oil pan of the 77 f150 had a humpin the center and 2 seperate drain plugs one in the front and one is the back is this a common set up for a 77 f150 302
Old Nov 5, 2011 | 07:54 AM
Franklin2's Avatar
Franklin2
No. That oil pan is from a late model car. That may suggest the whole engine is from a later model car(80's-up).
Old Nov 5, 2011 | 04:39 PM
trumsey07's Avatar
trumsey07
makes sence the 77 i pulled the motor out of had weird motor mounts and the frame perches were notched out for the car 302 i looked on the door and the number said the truck originally came with a 302
Old Nov 5, 2011 | 06:47 PM
GLR's Avatar
GLR
Ford went to that dbl hump when they came out with the new frame in 1979. It would be nice if it were an 86-91 EFI converted to carb, it had a roller cam. 79-81 maybe 82 used the VV carb, then went to throttle body injection until 86, Then EFI.
Old Nov 5, 2011 | 10:07 PM
83capril's Avatar
83capril
Pull the intake and look for the "dog bones" that hold the lifters in place. Should look like this....
http://img378.imageshack.us/img378/6442/dscn1319bv0.jpg
then you will know if it's roller or flat tappet. I'm fairly sure not all 86-91 302's were roller. I could be wrong tho. Been awhile since I looked into it. If it was a HO motor it was a roller for the 302's then.
Old Nov 6, 2011 | 07:58 AM
Franklin2's Avatar
Franklin2
Most cars were roller, trucks were not till later. But, that doesn't mean the trucks did not have the roller block with regular lifters in it. They did this for awhile, and these blocks can be converted with a little drilling and tapping.
Old Nov 6, 2011 | 09:44 AM
83capril's Avatar
83capril
I knew that the truck motors had the ability to become rollers. I just thought that in the 80's the HO engiens got the roller lifters. Then the non HO were flat tappet. Either way it is what it is. Good luck om the engien transplant. I hope it goes well.
Old Nov 6, 2011 | 09:02 PM
trumsey07's Avatar
trumsey07
i already did this swap about 2 months ago and the rear main started to leak badly so i tried to do the rear main with the motor in the truck but couldn get the oil pan off because of the double hump and i replaced the valve covers and yep roller rockers
Old Nov 7, 2011 | 04:53 AM
Greyf100's Avatar
Greyf100
HO v Non HO were a firing order change and different cam profile (i think). THe motor is my truck now is an '88/'89 Non-HO Roller motor
Old Nov 7, 2011 | 04:56 AM
Greyf100's Avatar
Greyf100
If it had roller rocker they arent stock. The roller refers to the method that the lifters contact the camshaft.
Roller on the right, flat tappet on the left
Old Nov 7, 2011 | 08:01 AM
GLR's Avatar
GLR
It could be stock. When Ford went to EFI in 86 (cars) the used roller lifters. 85 302 I had did not. 86, and a couple of 89's I re-did had rollers. As evident by above pics, the push rods have to be shorter for the roller engine. For some reason - probably money- for didn't use roller rockers.
Old Nov 7, 2011 | 08:55 AM
83capril's Avatar
83capril
This is true along with the gear on the distributor being steel on the HO engines. The HO has the 351W firing order. Some say it is running a marine 351W cam. Who really knows anymore.... Some of the HO engines had better pistons then other HOs'. It's all about doing your homework and study. I am still learning new things on these old push rod engines. I'll leave the Modular ones alone for now. LOL
Old Nov 7, 2011 | 09:23 AM
Greyf100's Avatar
Greyf100
As far as mustang motors go: 86-92 were HO firing order, roller cams, and forged internals. In '93 they switchted to Hyperutectic pistons.
and if you are converting an EFI motor to DSII / carb you can use an '85 Mustang distributor ($50 NEW, entire distributor) but it has to be from / for a manual trans car (Auto trans had EFI, also Calif Emissions cars had EFI). '85 was the ONLY year that had a CArb, the correct gear for the Roller cam, vacuum advance, & the DSII ign hookups.
302RP
Aug 13, 2007 11:52 AM
fordfan302
Engine Swaps
Dec 24, 2005 08:40 AM
kevs66coupe
Aug 19, 2004 08:03 AM
DFred40
1997 - 2003 F150
Aug 25, 2002 03:54 AM
be_likemike
May 22, 2001 04:01 PM
