Ground locations
Old Nov 4, 2011 | 04:07 PM
89formula's Avatar
89formula
Ground locations
Can anybody tell or describe where ALL the grounds are in the engine compartment? The issue I'm having is a slow drain on the batteries, once a week I will have to put the batteries on the charger because they are to low to start the truck. I'm thinking that the batteries are dying but, before I spend the money on new batteries would like to make sure everything else is good.
Old Nov 4, 2011 | 05:58 PM
Rusty Axlerod's Avatar
Rusty Axlerod
It's been awhile since I checked mine so I had to look. The driver side battery Neg goes to the top of the frame near the steering box. The passengers side batt Neg goes to the front of the block on the passengers side under a bolt that holds a support bracket for the trans cooling lines. There is also a short ground between that same bolt and the frame on that side.
There is a smaller gauge ground from the back of the block to the firewall but I think it's for electrical "bonding" and isn't supposed to be carrying a big load.
There are other smaller grounds also but if the big ones for the battery connections are good you should have no problems starting and charging.
There was a thread about slow drain on batteries a few weeks ago that had the info about the computer Keep Alive Memory requirements, what fuses to pull etc. Might be a big help to you if you can find it.
Old Nov 4, 2011 | 06:02 PM
brickie's Avatar
brickie
The passengers underside of the block has the main ground,the ficm has a ground on the last stud on the valve cover and the back of the passenger head had another.There may be other ones that I don't know of.
Old Nov 4, 2011 | 07:10 PM
69cj's Avatar
69cj
A poor ground will not cause the batteries to drain with the truck turned off. A poor ground may prevent proper charging but not a drain. You probably have a battery or both dying and you'd better address it before you have to replace the ficm also.
Old Nov 4, 2011 | 09:23 PM
89formula's Avatar
89formula
Actually pretty sure I do have a battery going bad, but just wanting to make sure everything else was fine. I know a bad ground won't drain a battery, but it also won't allow it to charge properly and can destroy the battery that way. Just trying to make sure that the grounds aren't the issue, because the batteries aren't more than a couple years old( not that I replaced what the build sticker says on the batteries.
Old Nov 4, 2011 | 09:45 PM
ford390gashog's Avatar
ford390gashog
Unhook the alternator and see if the voltage loss stops!
Old Nov 4, 2011 | 10:04 PM
bismic's Avatar
bismic
+1 .
Old Nov 5, 2011 | 06:40 AM
89formula's Avatar
89formula
Had the alternator load tested a couple of days ago and it tested fine 14.6v at idle and 13.9v under load, and the diode was good.
Old Nov 5, 2011 | 06:49 AM
Rusty Axlerod
This can be a PITA problem. This thread has some good info that might help:
https://www.ford-trucks.com/forums/1...ery-drain.html
Good luck!
Markus Luukko
Mar 9, 2018 02:47 PM
16Vjohn
22
Jan 19, 2013 04:48 PM
Copedawg
15
Jul 3, 2009 06:48 AM
cjspack
Jul 31, 2007 08:39 AM
lawngnome
Mar 6, 2004 12:30 PM
