Why dead batteries?
Old Jul 29, 2007 | 09:47 AM
cjspack's Avatar
cjspack
Why dead batteries?
I need help! When trying to start my X (2000 psd) after it sits for three or more days, the batteries are dead. The batteries and alternator have been tested and they are good. The interior lights and other electrical components all appear to be off. If it sits for two days or less there seems to be no problem. Any suggestions would be appreciated.
Old Jul 29, 2007 | 01:53 PM
Monsta's Avatar
Monsta
Sit. Stay.
You can put a multi-meter between the positive cable & terminal. Simply pull the cable off and put it between the two. Then pull fuses until the drain (reading) drops. There should be a minimal amount of drain (usage) to keep all the memories alive (radio, PCM etc.) but it should be minimal as in Milliamp minimal. I can't remember the exact amount but a search in the SD forum should turn up the number.
Don't turn the truck on or try to start it with a household multimeter in line. I believe it may fry it. It shouldn't be running or started anyway to help you find the source of the drain.
Old Jul 31, 2007 | 07:49 AM
XNrepair's Avatar
XNrepair
you might make sure you don't have any accessories plugged into you cigarette lighter (DC) power outlets ? Electrical issues are some of the worst to trouble shoot.
Old Jul 31, 2007 | 08:39 AM
DSMMH's Avatar
DSMMH
Load Test Batteries
Don't know how old your batteries are but I recently had the same experience on 3 year old Wal-Mart MAXX batteries except it was on one of my farm tractors. I found that one battery would not sustain a charge and the other would. This would lead to both batteries, over a 2 to 4 day period, going bad as one would discharge the other. I had to use a battery load tester to determine this. If you did not load test you batteries to ensure they are good, I would suggest you do so.
DSMMH
