engine bay wiring (rat) issues
Old Nov 4, 2011 | 02:12 PM
Ronh66's Avatar
Ronh66
I was recently given a 1985 f-150 single cab SWB 5.0FI w/4 speed from my wifes grandpa. He was the original owner. The truck has been parked for roughly the last 5 years, but was running fine at that time (he just wanted a new truck). I went out today to see if I could get the engine to turn over, and I was a little shocked at the damage that rats have caused in the engine bay.
There are lots of wires that have been chewed through, including the ones going to the regulator on the passenger side firewall. Most of the wires I will be able to splice back together. The wires going to the regulator are chewed through too close to the connector for me to be able to splice. What would be the best way (not necessarily easiest or cheapest) to fix the wires going there?
Also there are two wires that are running from the back firewall that are completely chewed through. They are two black wires that were protected by tubing, and look like they should run up the middle of the engine to the front. Does anyone know where I can get a wiring diagram for the compartment to find what these wires are, and where they are supposed to go?
Old Nov 4, 2011 | 03:03 PM
Franklin2's Avatar
Franklin2
Autozone has a few generic freebies, but they do not cover much. Service Manuals, Owner Manuals, Wiring Diagrams, Service Bulletins - Helm Incorporated is the supplier for the factory manuals and diagrams, and you can check there to see if they have any for your truck.
You can also check the parts stores for the regulator wiring. Sometimes they sell new connectors with short pigtails coming out of the connector to splice back into the wiring. I know they sell some of the headlight switch connectors, and they may have the regulator connector also.
Old Nov 4, 2011 | 07:27 PM
ctubutis's Avatar
ctubutis
Welcome to FTE.
I have bought from this place and am happy, found them on ebay.
Here is for your 1985 wiring diagram:
Lloyds Auto Liturature available for 1985, Fordtruck, Wiring Diagrams
Yes, see if the parts stores have pigtail-type replacement connectors for the regulator, some stores that have HELP! stuff have a HELP! catalog of things they can order.
These two links might help ya, too:
http://www.rowand.net/Shop/Tech/Auto...Connectors.htm
http://www.weatherpack.com/
Junkyard might be a good bet if you can find such wiring in decent shape (look on cars, too).
Ed Allen
Dec 28, 2020 11:09 PM
therigwelder
Nov 26, 2015 10:01 PM
Milwaukee1979F150
Jun 1, 2011 02:04 PM
