starting problems
Old Nov 4, 2011 | 01:57 PM
yendor0801's Avatar
yendor0801
starting problems
Has anyone had problem, when you turn the key on, the radio and everything comes on but the starter never starts, just nothing. I then have to put it in nuetral and then back in drive a couple of times then it starts. Has anyone seen this issue. Thanks for your help.
Rodney
Old Nov 4, 2011 | 03:04 PM
chperry's Avatar
chperry
I had that happen on a 65 Mustang ;-) Sounds like a neutral safety switch problem to me.
Old Nov 4, 2011 | 06:47 PM
FORDTUF1's Avatar
FORDTUF1
Rodney
I guess then back into Park to actually start it, not in Drive?
Try holding the key turned to try and start it, then wiggle the shifting lever around in the Park position and see if it starts. It might just be a loose safty switch in the column.
Old Nov 4, 2011 | 07:47 PM
brmpipes's Avatar
brmpipes
maybe bent linkage
thinksnow
Nov 22, 2007 11:05 AM
73strokin
Oct 28, 2007 09:21 AM
neetso
Electrical Systems/Wiring
May 15, 2004 08:33 AM
orange peel
Apr 10, 2002 12:42 AM
