installing body lift problems!
Old 11-04-2011, 09:19 PM
95f150mudder's Avatar
95f150mudder
95f150mudder is offline
im installing a 3" body lift on my 1995 f-150. i did the bed fine and now that it was time to do the cab i cant get any of the bolts to budge and the front two bolts jsut spin cause the radiator support is rotted out. does anyone have any tips or tricks that can help me out with getting the cab done?
thanks,
Bill
Old 11-04-2011, 09:44 PM
Beatertruck's Avatar
Beatertruck
Beatertruck is offline
thanks,
Bill
The bolts on the radiator support can be cut off with a sawzall. Soak the other bolts with nutbuster overnight and clean the threads with a wire wheel. If all else fails hit them with a little heat and try it again.
Old 11-04-2011, 09:46 PM
minnesotafisherman's Avatar
minnesotafisherman
minnesotafisherman is offline
Hey Bill, I just did a 3" body lift on my truck a couple weeks ago. I had no problem with the front 2 as I had my radiator support + the 2 front bushings and bolts all replaced so those came out fine.. but as for the 4 cab bolts, I used my 4.5" grinder to cut the bolts off from the underside and popped them through the top. If you don't want to go to that extent like I did, then use some PB Blaster to try and free up the bolts.
By the way how did the bed go for you? I had to grind all 6 of my bed bolts off cause they were so rusty I couldn't get them to move.
Old 11-04-2011, 09:53 PM
95f150mudder
im probably gonna have to grind off all the bolts for the cab but the bed bolts werent too bad. i grinded a groove in the top of the bolt so someone could hold a screewdriver so that part was pretty easy.
Old 11-04-2011, 11:15 PM
minnesotafisherman
Yeah when I cut my cab bolts off I had to cut the nut off too. so you're going to need to get some new nuts to fit on the body lift kit bolts because the kit doesn't come with any. (They expect you to re-use the factory Ford nuts) So I brought my 4 cab bolts into Fastenal and they hooked me up with some lock nuts for them.
GearJaminOutlaw
03-09-2009 02:10 AM
1986fordrangerman
1997 - 2003 F150
11-28-2008 09:21 PM
RockWVU
02-26-2008 08:16 PM
westsideblackshi
12-04-2005 08:16 PM
lilredhorse
1978 - 1996 Big Bronco
06-25-2000 08:18 AM
Quick Reply: installing body lift problems!
