1978 - 1996 Big Bronco
BODY BOLTS
Old Jun 16, 2000 | 12:32 PM
lilredhorse's Avatar
lilredhorse
BODY BOLTS
HOWDY....I NOW HAVE A 3" BODY LIFT INSTALLED IN MY 89. I WANT TO REMOVE THE BODY LIFT AND GET A 6" SUSPENSION LIFT. I WENT TO THE DEALER TO GET NEW STOCK BODY BOLTS, AND THEY SAID THAT ALL THE BOLTS ARE THE SAME LENGTH, 100mm. IF I REMEMBER CORRECTLY, THE LENGHT OF THE BODY BOLTS WAS DIFFERENT DEPENDING ON WHERE THEY WERE LOCATED. ALSO, THEY SELL THEM IN PACKS OF 4. WHY, I DONT KNOW......THERE ARE 10 BOLTS TOTAL. CAN ANYONE HELP ME WITH THIS, BECAUSE I DONT WANT TO SPEND $40 ON BOLTS THAT ARENT RIGHT.
THANKS
Old Jun 25, 2000 | 12:58 AM
nhmuddrunner's Avatar
nhmuddrunner
BODY BOLTS
If I remmember the two rear are slightly longer and the two at the radiator support are also different in length but I don't remmember if they are longer or shorter. The bolts that are in there are not specail bolt though, the dealer I deal with out here in NH says grade 5. You could buy those in a hardware store for a lot less coin. As far as those four packs go, simple-MONEY!! They charge more for the 4 packs and since you can't buy singles from them they know you will have to buy three packs instead of two and a couple bolts.
Good luck.
Mudd
If it's stuck, force it. If it breaks, it needed replacing anyway!!
Old Jun 25, 2000 | 08:18 AM
Phillip Guidry's Avatar
Phillip Guidry
BODY BOLTS
