ATF fluid
Old 11-03-2011, 09:01 PM
kbf1961's Avatar
kbf1961
kbf1961 is offline
ATF fluid
Local part store only has Mercon V. Is this acceptable .
Old 11-03-2011, 09:18 PM
desertnomad's Avatar
desertnomad
desertnomad is offline
I don't believe it is but I didn't take chances so ordered the Mercon SP XT-6-QSP from tousleyfordparts.com. diesel-filters.com also has it.
Old 11-03-2011, 09:23 PM
Unrealo4's Avatar
Unrealo4
Unrealo4 is offline
Mercron SP or LV only!
Old 11-04-2011, 01:09 AM
XB70's Avatar
XB70
XB70 is offline
There are O'Reilly's stores in Washington. They carry Mercon SP and LV at prices well below Ford dealers. Although I can't remember the exact name, there is a Valvoline ATF that meets Mercon SP/LV specs. If you decide to use Valvoline, make sure it's the correct spec.
Found it:
Valvoline.com > Products > Automatic Transmission Products > Automatic Transmission Fluid > MaxLife® DEX/MERC ATF
Old 11-04-2011, 05:10 AM
wulfman's Avatar
wulfman
wulfman is offline
What XB said, O'Reilly's has the mercon sp i just got some from them 4.50 or so a quart. The val max life is 6.00 plus a quart way to much.
Old 11-04-2011, 09:06 AM
Beachbumcook's Avatar
Beachbumcook
Beachbumcook is offline
Got Diesel?
Mercon SP is the fluid that was in our trucks from the factory and a good fluid at that.
Mercon LV is a new fluid, and has been approved for our trucks.
I personally use Mercon SP as that is what I have always used and it is still available (for less I think).
I would NOT use multi-spec'd fluids or any other type of fluid claiming to be universal in nature or meets different spec's... just use a single spec'd fluid of either Mercon SP or LV... again, I hate mixing fluids... so I just stay with "SP" until it is fazed out (who knows when).
I change the internal and external filters every 30,000 miles (drop pan and refill)... and the pan has always been spotless.
Old 11-04-2011, 09:12 AM
69cj's Avatar
69cj
69cj is online now
LV is a buck a qt. cheaper than SP at our dealership.
Old 11-04-2011, 10:05 AM
bismic's Avatar
bismic
bismic is online now
Received 2,522 Likes on 1,754 Posts
Pretty sure that I have seen Mark Kovalsky post up that the Valvoline MaxLife is an acceptable fluid. I also know that at least one person has used the Royal Purple "equivalent" for quite a few miles with good results.
That being said, I have stuck w/ SP also.
Old 11-04-2011, 11:45 AM
XB70's Avatar
XB70
XB70 is offline
That's because there are guys like Beachbumcook who will pay more for vintage reserve.
Old 11-04-2011, 12:54 PM
Beachbumcook
Got Diesel?
Wow, that was a very nice complement.
I like vintage reserve cigars, wine and scotch.
Also, here a few quotes that support me using only Mercon SP fluid:
1) If it works, stay with it.
2) Let sleeping dogs lie.
3) Don't stir a turd that isn't stinking.
I now have 201,000 miles on my truck and I change the fluid and filters every 30,000 miles (as directed in the manual).
I alternate between drain/refill and flushing the entire system (always changing the external filter). I am starting to think that just a drain and refill (both filters) every 30,000 miles is all I now need.
I do not tow much, but the tranny cooler and external filter really help keep the tranny and fluid performing very well.
Old 11-04-2011, 05:46 PM
XB70's Avatar
XB70
XB70 is offline
Last time I checked, O'Reilly's was selling SP for less than LV. Since SP is no longer manufactured, you might want to stock up. I use SP, and will continue as long as I can get it and it's Cheaper than LV. Mike Kolvasky says it's compatible with SP, and that's good enough for me.
If LV was cheaper, I would use it now.
Old 11-04-2011, 05:54 PM
69cj's Avatar
69cj
69cj is online now
The LV was 4 and change at our dealer per qt.
Old 11-04-2011, 06:11 PM
Rusty Axlerod's Avatar
Rusty Axlerod
Rusty Axlerod is offline
Just bought 8qt of SP (p/n XT-6-QSP) from my local dealership. List price $9.34 but I got a great deal, only $7.01 a quart!
Old 11-04-2011, 07:31 PM
wulfman's Avatar
wulfman
wulfman is offline
Rusty did they use lube when you paid 7 bucks a quart? Orielly's has it for 4.50 or so.
Old 11-04-2011, 07:49 PM
Rusty Axlerod
No lube. Trans filter was $43.19 list $32.39 out the door.. No reach around either!
I did get the full blue spring kit (with cover) for $64.62, didn't think that was TOO bad.
Definitely be ordering online next time. The parts man had his way with me. Found out earlier today that I got a free weekend and wanted to get some stuff done. Didnt ask prices until i was checkin out. At least I get to throw away some genuine Motorcraft trans fluid bottles!
Quick Reply: ATF fluid
