Best ECT
Old Nov 3, 2011 | 04:38 AM
JonArmy's Avatar
JonArmy
Best ECT
Currently after I had a coolent "flush" from my FMC I look at my SGII and my coolent tempature usually stays around 182 to touching 190. Does that sound "normal" or should I look into doing a proper "flush" and install a new thermostat. My deltas are usually over the 15* runs around 20* delta. I'm going to install a coolent filter soon.
Old Nov 3, 2011 | 05:12 AM
npccpartsman's Avatar
npccpartsman
If your coolant is staying at 182 you need a thermostat. It should be 188-193 minimum.
Old Nov 3, 2011 | 05:14 AM
wulfman's Avatar
wulfman
Well it sounds like the thermostat is a little weak should be at 190 or above and the spread is a little high also . Doing a proper coolant flush might help or might make it worse. Coolant filter will start cleaning things up.
Old Nov 3, 2011 | 05:16 AM
wulfman's Avatar
wulfman
Dang partsman you always beat me in the morning .
Old Nov 3, 2011 | 03:23 PM
JonArmy's Avatar
JonArmy
Thanks, I figured after awhile that something was slightly off. Hopefully by the end of the month I'll have a coolent filter put on with new thermostat. Probably in December I'll be able to get a proper coolent flush done.
Old Nov 3, 2011 | 06:16 PM
npccpartsman
and I'm on central time David.......
Like the saying goes, "I'll get enough sleep when I'm dead".
Danner717
Jan 13, 2016 01:52 AM
Jarhead97
Nov 12, 2012 06:37 AM
jaberwocky
2004 - 2008 F150
23
Feb 20, 2009 01:26 PM
King0581
Apr 13, 2008 04:16 PM
rlp
Nov 26, 2003 02:19 PM
