Recommendations for Ignition upgrade?
Old Apr 11, 2003 | 10:36 AM
newinlinesixguy's Avatar
newinlinesixguy
Okay guys...I know a significant number of you out there have and recommend an ignition upgrade can you all pass on your preference and why/how it worked out for you?
It is a little confusing looking at all the different manufacturers and the different selection.
Thanks..Look forward to your response.
Old Apr 11, 2003 | 02:48 PM
Ford_Six's Avatar
Ford_Six
I have an HEI system from Performance Distributors, and it was one of the best upgrades I ever made to anything. A little pricey, just under $400 delivered, but no more high end misfire, no wiring problems, no burned out ignition modules, just runs. Tons more towing power too-
Old Apr 11, 2003 | 07:25 PM
newinlinesixguy
Sooo..your bottom end(tourque) went up quite a bit or do you mean you have more power in the higher rpms?
Jeff
Old Apr 11, 2003 | 08:01 PM
Njbmx's Avatar
Njbmx
how 'bout msd box, coil, and wires w/ the stock durospark II distributer? that would be less money then the DWI distributer
Old Apr 12, 2003 | 08:55 AM
newinlinesixguy
If you are moving to a ignition system with a bigger spark could the stock duraspark II distributor handle it(hotter spark) from an upgraded coil and box?
Is my thinking off on this?
Jeff
Old Apr 12, 2003 | 05:00 PM
tetraruby's Avatar
tetraruby
I've been running a MSD6A and the 2F on my DII dizzy for a year now and I've had no problems at all. Install wasn't difficult, price was decent.
Old Apr 13, 2003 | 12:16 AM
newinlinesixguy
Can I ask where you got it?
Jeff
Old Apr 13, 2003 | 12:25 AM
tetraruby's Avatar
tetraruby
I bought my MSD box, coil, and DII adapter from PAW. The box was around $150, the coil was around $30, and the harness was another $15. Prices are about the same everywhere. You could try ebay, but I wouldn't buy an pre-owned electronic component like this. The service and response was professional, as most of the larger suppliers like Jegs and Summit are. My only complaint is the leads off the MSD box are way to short for a clean install. I had to buy a bunch of wire (to keep the color coding) and extend the stock leads...a lot depends on how you want to set it up. I stated install was easy - that was on my '79 F100. Search this topic, there have been a number of threads about the aftermarket ignition setups.
Old Apr 13, 2003 | 09:21 AM
newinlinesixguy
Gerat thanks..I appreciate it.
Jeff
Old Apr 22, 2003 | 09:50 PM
battered_bronco's Avatar
battered_bronco
ok just wondering
maybe gettin a 150 with a 300 six and is it needed to to change the springs/ counter-weights in the dizzy for high end use
probally a good idea but wondering
Old Apr 23, 2003 | 08:37 AM
newinlinesixguy
What do you mean by high end use?
Old Apr 23, 2003 | 09:04 AM
desperado_18_2000's Avatar
desperado_18_2000
Changing the springs & weights in the distributor allows for more centrifugal advance than you would normally have out of a stock distributor.
Unless its going to be wound up sky high, then i wouldn't get too radical with it,.
Old Apr 23, 2003 | 08:59 PM
benwantland's Avatar
benwantland
hey newinlinesixguy, be careful about thinking that what you're reading here will apply to your truck.... it looks like most everyone that has posted here has an older carbureted truck that originally had a DS II system; I don't know how the ignition is controlled on your EFI truck, but I would guess it's all wrapped up in the computer system? I don't know... just something to think about.
Old Apr 23, 2003 | 10:20 PM
desperado_18_2000
Newinlinesixguy:
Some people have had great results with MSD Ignition components. A spark control box, coil, wires and all your typical ignition tune up stuff.
I imagine you could get all the MSD stuff you'd need for about $250 bucks new. you might get a good deal on it used, but i'd shy away from that as you don't know the condition other than what you've been told.
Old Apr 24, 2003 | 08:56 AM
newinlinesixguy
Thanks for the input guys.
I am slowly going through the truck an replacing components that will help its performance and basic mechanical soundness. I don't know the history of the truck but I think it used to be a farm truck that was rode hard and put away wet.
Some of the parts were on the verge of falling off the truck. It would appear that whoever had it before I did tried to repaint it and cosmetically clean it up.
So I am inside of it replacing and upgrading so all of the posts are extremely helpful.
Thanks again.
Jeff
GolemintheGears
19
Nov 17, 2013 09:28 PM
dyhrdford
Jan 9, 2011 10:30 PM
Zartman456
Dec 12, 2008 11:36 AM
debestuss
Apr 26, 2005 04:36 PM
billome
Feb 19, 2001 10:31 PM
