valley pan?
Old Nov 2, 2011 | 11:25 AM
finneys98xj's Avatar
finneys98xj
valley pan?
Should I reuse mu valley pan when I put my motor back together or just leave it off?
Old Nov 2, 2011 | 11:26 AM
finneys98xj
All so I have a set of cork gaskets which of the pan should I use them on if I use the pan?
Old Nov 2, 2011 | 05:43 PM
crsmiffy's Avatar
crsmiffy
Up to you. If it's still in good order re-use it. They are not onlyto prevent hot oil touching the manifold heating it up, the same oil can apparently cook off as it Touches the manifold where the exhaust gases cross over. This can make ash/carbon deposits which end up in the engine. Cork end gaskets are good and are more user friendly than the rubber ones
Old Nov 2, 2011 | 05:58 PM
finneys98xj
Which sid of the pan should the gaskets go on? toward head or manifold?
Old Nov 2, 2011 | 06:08 PM
crsmiffy's Avatar
crsmiffy
That is a very good question. Sorry When you mentioned gaskets I wrongly assumed you meant the end gaskets. I had an aftermarket alloy manifold and good gaskets that blocked off the exhaust ports on the heads so I didn't even use my brand new pan. I would sit it in the valley and see the what the clearance is as to wether or not its the pan to the heads or the gaskets. Unless there is a factory specified procedure some-one else out there knows about that is? If the pan is utilised with sealant do you even need the gaskets?
Old Nov 5, 2011 | 09:06 PM
dlapl390's Avatar
dlapl390
Hey Ford Truck Guy,
thanks for the reply, if you do see a D5AE-BA Head please let me know.
dlapl390@yahoo.com or 405-227-8556 or 858-560-1957. Consideration appreciated.
Dan
matz250
May 31, 2018 12:22 AM
PapaBearYuma
Apr 14, 2017 04:33 PM
rodneywar
May 10, 2010 07:13 PM
guywhalen00
Jul 5, 2007 07:18 AM
78'fordtruckguy
Jan 8, 2007 10:14 PM
