computer problems
on
What trans does your '89 have?
A '94 F150 will have one of the computer controlled auto transmissions in it(most likely) and it's not likely your '89 does so the '94 computer won't be of any use to you. You need a 5.8 computer from an earlier truck with either a C6(3spd) auto or manual trans, and hopefully you did not install the flywheel/flexplate that came with the 5.8 or used the one from your 5.0, because neither of these are correct for the 5.8 in your truck and if you have an AOD you will destroy the transmission the first time you fire it.
needs more mudd
11-03-2012 01:36 AM
tinbender71
06-05-2006 08:25 PM
