302-351 swap computer problems
Old Jun 4, 2006 | 06:59 PM
tinbender71's Avatar
tinbender71
All right I have a long one...sorry! I have a 1988 F-150 with FI 302/AOD. Motor was weak, so I bought a 1991 E-250 with FI351/E4OD with a fresh engine (know history of van, is from my employer). After reading this forum I decided this was a good swap. OK, after installed (with correct flywheel) it would not idle right, missing and stumbling, also since truck is OD, @1500 rpm is cruising, it would surge. Have checked every sensor and are within range. Have found a ton of info from this forum. Finally got bored yesterday and pulled computer from van, and runs perfect. Codes have shown up about transmission: circiut failure to shift soelinoids, but runs smooth. I did leave the aod. Now the truck started to have this problem with 302, just figured it was bad engine. So my question is do I leave the van computer, or do I need to find the correct one for my application? I am thinking of similar year with 351/c-6. OR is there one for 351/AOD? I am wondering if my stock computer was going bad. It was also getting hard to start, turn over for a long time, then barely idle. Sorry for the long post, but this may help several people thinking of this.
Pat
Old Jun 4, 2006 | 09:01 PM
frederic's Avatar
frederic
Right.
The EEC from the van is expecting to find, and operate, a E40D. Your truck currently has the AOD, correct? If so, that's why the computer is giving codes. It's not finding what it's expecting - a particular transmission.
Old Jun 4, 2006 | 10:44 PM
water 5's Avatar
water 5
the E4OD is a good trans why not use it too and the computer set up
Old Jun 5, 2006 | 06:03 AM
tinbender71
Thanks for the replies, I used the aod because I just had it rebuilt. Now I am looking for the correct computer for my application.
Old Jun 5, 2006 | 06:40 AM
frederic's Avatar
frederic
88-89 351-powered F-truck or E-van will have a usable EEC, as the E40D's didn't come out until later.
BTW, you can use a manual transmission EEC as well. Since the computer doesn't shift the transmission, it wouldn't matter.
Old Jun 5, 2006 | 07:24 AM
subford's Avatar
subford
The 91 and 88 have different wiring to the IDM, the 88 would have been running under base timing with no advance, you need an EEC (PCM) from a 5.0 or 5.7 from 1991 with a manual transmission.
Old Jun 5, 2006 | 10:37 AM
EPNCSU2006's Avatar
EPNCSU2006
Doesn't the IDM still connect to the same pin on the computer though?
Old Jun 5, 2006 | 11:14 AM
Kemicalburns's Avatar
Kemicalburns
the van ecu will work but throw a tranny code but will not affect driveability. the correct ecu to get though would be a 351w/c6 ecu, the manual equivelent would be hard to find because they were rare.
Old Jun 5, 2006 | 12:12 PM
subford's Avatar
subford
Yes.
My mistake, I read it backwards, I had it as a 88 E250 and 1991 F150 that were different but the 88 F150 5.0 and the 1991 E250 5.7 Van are the same.
Unless my source diagrams are wrong.
Old Jun 5, 2006 | 12:57 PM
Kemicalburns
how about a 5.8. the 5.7 is a chevy thing
Old Jun 5, 2006 | 01:23 PM
subford's Avatar
subford
Got me, they put them numbers next to each other on the keyboard and I hit the wrong one.
I have two of them, a 351M in a 77 F250 and 351W in an 83 F150.
Old Jun 5, 2006 | 06:51 PM
tinbender71
Thankyou very much for the info. I am going to my favorite wrecking yard tomorrow to look. By the way, yesterday and this morning it ran perfect, but with check engine light on. This afternoon it seemed a little sluggish, and did not seem to be idling as smooth. I thought i was getting pretty literate on this ecu terminology: what is IDM?
Old Jun 5, 2006 | 08:25 PM
subford's Avatar
subford
IDM (Ignition Diagnostic Monitor) is the signal that comes in to the EEC (Electronic Engine Control) module or PCM (Powertrain Control Module) at Pin #4 from the ICM (Ignition Control Module) Pin #3 or TFI (Thick Film Ignition system) module Pin #5.
