Romp Problem
Old Nov 2, 2011 | 10:28 AM
Munch's Avatar
Munch
Romp Problem
I am getting a Romp Romp Romp still. I have changed the batteries, GPR, Glow Plugs, and 50cent mod. It was only -2 degrees C this morning. Left the Glow plugs on for a couple minutes before firing. Only thing I havent changed is the 15w40 rotella. Could it be to heavy of oil or am I missing something else in the warm up period?
Old Nov 2, 2011 | 11:34 AM
01PS's Avatar
01PS
Ford has said that "this is a characteristic of the motor". I gave up trying to get rid of it. If the truck starts, I am happy!
Old Nov 2, 2011 | 12:11 PM
kawcrasher's Avatar
kawcrasher
I have decided if it's below 30f I just plug it in. Mine has started down to 24 this year with only 1 or 2 romps, but I have just started plugging it in. The starter sounds much happier and I have heat right away. Water is around 140f and oil about 90f when plugged in.
Old Nov 2, 2011 | 12:20 PM
BigAlsPSD's Avatar
BigAlsPSD
No romps for me after switching to Rotella T6 5W-40 synthetic.
Old Nov 2, 2011 | 12:25 PM
nlemerise's Avatar
nlemerise
There is your answer to romps...I have started at -15 F or so with no romps. I only use it in the winter and it SOLVES the problem.
Old Nov 2, 2011 | 12:28 PM
nlemerise's Avatar
nlemerise
Originally Posted by kawcrasher
I have decided if it's below 30f I just plug it in. Mine has started down to 24 this year with only 1 or 2 romps, but I have just started plugging it in. The starter sounds much happier and I have heat right away. Water is around 140f and about 90f when plugged in.
Get a timer and run it for about 2-3 hours just before startup...save alot on electric bill (if you plug it in for 8 hrs/night it will add about $1/day to your electric bill). Three hours will have everything good and warm...but 5-40 syn in the winter will make everything happier.
Old Nov 2, 2011 | 12:29 PM
dagren99's Avatar
dagren99
Some trucks seem to be more prone to get the "romps" than others. My 00 rarely does it and even then it has to be single digit cold out w/o plugging it in to do it again all while running dino 15W40. We have a couple of other trucks of the same age that'll romp even @ modestly cold temps. (20's)
Don't really know why but we've always chocked it up to differences in hpop's, sensors & injectors. All running same fuel, oil, filters and have been similarly maintained and driven. This has been the way of things since they were all new.
Old Nov 2, 2011 | 02:04 PM
rufushusky's Avatar
rufushusky
Next time you change your oil try something like Rotella t5 10w-30 or t6 5w-40. I started my truck at 28*F, by no means too cold, but the truck didn't romp at all.
Old Nov 2, 2011 | 08:07 PM
Munch's Avatar
Munch
I usually run Rotella T 15w40 non synthetic, so Ill switch over to 5w40 synthetic for the winter but what about in the summer. Should I continue running the 5w40 syn or can I switch back to a 15w40 non syn?
Old Nov 2, 2011 | 08:16 PM
rufushusky's Avatar
rufushusky
Your choice, IMHO I would run the conventional for most of the year and t5 or t6 in the winter. If you want you can run synthetic year round no problem. Many do, i don't strictly cause of the cost.
Old Nov 2, 2011 | 08:19 PM
BigAlsPSD's Avatar
BigAlsPSD
I personally run T6 year round.
Old Nov 2, 2011 | 08:29 PM
jc8825's Avatar
jc8825
I run 15W40 year round and plug the truck in if the temp drops down below freezing. 'Romps' don't bother me. It is what it is and the 7.3 is cold-blooded.
Old Nov 2, 2011 | 08:33 PM
rufushusky's Avatar
rufushusky
See what bothers me is how sluggish the truck will feel when cold running 15w40 in the cold. Feels like I an driving an oversized k-car but I also don't plug my truck in ever.
90pioneer
Jan 23, 2015 12:14 PM
1994F2507.3L
Dec 7, 2013 10:28 AM
getout
May 11, 2011 06:48 AM
WonderDonkey
Feb 1, 2008 12:12 PM
TheBludgeon
Jan 18, 2007 07:11 PM
