most recent flash software
Old Nov 1, 2011 | 07:04 PM
powerstroker100's Avatar
powerstroker100
I'm thinking my truck has the original flash software
how much does it usually cost to have these trucks updated with the newer software? like to get my truck done
Old Nov 1, 2011 | 07:40 PM
BobsF350's Avatar
BobsF350
about 100.00
Old Nov 1, 2011 | 07:44 PM
powerstroker100
thanks bob350
Old Nov 1, 2011 | 07:45 PM
zhilton's Avatar
zhilton
Call your local dealership and see what they say, might get a "free flash" for transmission flush.
That didn't come out the right way...
Old Nov 1, 2011 | 07:53 PM
Tylus's Avatar
Tylus
MMNC (SS)(Ret)
Veteran: Navy
You might want to rethink that.
Sometimes the newest flashes aren't the best. Look at the FICM programming. Early flashes got better MPG and power
Old Nov 1, 2011 | 08:02 PM
powerstroker100
hahaha
this was something I went through back when I had my 04 6.0 but figured they mightve come out with a new one within the last year and half that should be really good? mainly I was looking to get it because I read that the new flashes disable the ebp sensor function on the 2003 6.0 engines
Old Nov 1, 2011 | 08:24 PM
zhilton's Avatar
zhilton
Something else to keep in mind, the last couple of flashes will disable the radiator fan if you unplug the EGR valve. I'm thinking the last 4-5 will buzz the coils as well, something else to consider.
Old Nov 2, 2011 | 05:24 AM
npccpartsman's Avatar
npccpartsman
Not on an 03/04 they won't. That's just the 05,6,7 trucks.
Old Nov 2, 2011 | 10:42 AM
cartmanea's Avatar
cartmanea
If you have an early '03 flash, keep it. You will lose power and mileage compared to the original flash.
Old Nov 2, 2011 | 02:54 PM
powerstroker100
I might start another thread about this, but the reason I was going to get the flash is so my ebp function is removed, my idle tone changes like every 30 seconds
sounds like the turbo spools way up then completely shuts down and a deep rumble sound comes then it goes back to the turbo whistle then to the rumbleing and it sounds horrible, I tried cleaning my ebp sensor and tube and it didnt do a dang thing
Old Nov 2, 2011 | 02:57 PM
cartmanea's Avatar
cartmanea
That could just be your EGR or turbo vanes cycling. If you don't have any driveability, power, or starting issues, I'd leave it alone.
Old Nov 2, 2011 | 03:04 PM
powerstroker100
after a few minutes of research I found some other people with the same idle tone change symptoms, apparently its from the newest flash it cycles the veins in the turbo so they will have a harder time to stick, my truck is perfectly fine, not going to bother with anything else
be sure to check out my thread I'm going to post with pictures of my truck!
Old Nov 2, 2011 | 05:20 PM
zhilton's Avatar
zhilton
That's exactly what it is...the servo "flexing" the vanes on the turbo. If your running a straight pipe or MIA kitty...you'll notice it too.
jhammond615
Sep 1, 2008 08:52 AM
Boo_Daddy
Sep 12, 2007 03:54 PM
strateman
Jun 20, 2005 10:50 PM
pocobueno
Feb 2, 2004 07:09 PM
