Clutch Problem.
Old Nov 1, 2011 | 04:58 PM
brcwelding's Avatar
brcwelding
Clutch Problem.
I just put a new clutch in my truck. Everything is working good but i have to push the clutch all the way to the floor as hard as i can to shift. If i dont the gears will grind. Any ideas what to do.
Old Nov 1, 2011 | 05:46 PM
mpc07005's Avatar
mpc07005
Yes, fix it (lol)
Post more info on your truck. Engine? Tranny? Year? Mechanical or Hydraulic? Internal or external slave? 4x4?
-Mike
Old Nov 2, 2011 | 06:07 AM
brcwelding's Avatar
brcwelding
Its an 88 f250 with a 351w 5 speed overdrive tranny, hydraulic, internal slave cylinder, 4wheel drive.
Old Nov 2, 2011 | 07:12 AM
White 97 xlt's Avatar
White 97 xlt
Make sure the firewall is in good shape.. as in not cracked and flexing, if it is there is a repair plate available for a fix.
You might want to follow along on this thread, https://www.ford-trucks.com/forums/1...rn-spring.html for some more ideas..
Old Nov 2, 2011 | 08:35 AM
mpc07005's Avatar
mpc07005
When you replaced the clutch, did you pull or drop the tranny. What did you replace? Do the lines need bleeding? Are you getting the full range of travel from your slave?
Your Haynes (or Chiltons) will tell you how to do/check all of this.
-Mike
robertother
59
Oct 14, 2013 06:51 AM
bmacky14
Jan 29, 2013 07:46 AM
Paramedpete1996F250
Dec 11, 2008 07:43 PM
84-F150
Apr 15, 2008 01:00 PM
brosko80
Feb 24, 2006 06:51 AM
