need some help here
Old Oct 31, 2011 | 09:47 PM
vasten's Avatar
vasten
need some help here
This weekend I was hauling some firewood with my 96 f-250, and I got her stuck real good. I locked in 4 wheel and stomped on the skinny pedal, and the front end started bucking. I got out and found out real quick I snapped the yoke on the passenger side axle shaft. Kind of the chicken or the egg not sure if the universal snapped and took out the yoke or the other way around, any way you look at it, it is still broke.
So, I looked up the used parts and not much luck, I did find one at a reasonable price under 100.00, but when I called to buy it I was told it would not fit my truck that it was for a dana 50 and my truck doesnt have one. When I went back to his search engine, put my info and it still shows that same part, as available for my truck. Do I just buy it and trust it will work and figure it out later. Or is there something else I should be looking at?
The truck has a front wheel GV of 4600 with an axle code of 35 ( which by the way I cant seem to locate for a 96 no listing of a 35 axle) Do I look at replacing the shaft or would I be better off trying to match the gearing and replace the entire front end as a complete unit? Or even better yet can you just buy the yoke from the universal to the hub? Any help would be appreciate this is my plow truck and we have already seen flurries here in the NE.
Old Nov 1, 2011 | 06:03 AM
tjc transport's Avatar
tjc transport
i ain't rite
look at the locking hub. if it is the same size as the mounting flange, it is a dana 50
if it is a bit smaller than the mounting flange, it is a dana 44
dana 50-dana 60
dana 44
Old Nov 1, 2011 | 06:40 AM
cj06's Avatar
cj06
do you have auto hubs ? dont know if the internals are the same !
Old Nov 1, 2011 | 08:08 PM
vasten's Avatar
vasten
ok I have manual hubs, and my hubs look more like the top pict than the lower pict. The appear wider at the wheel and narrower at the hub. Plus the door pillar sticker says 4600. which to me states it is the larger of the two front ends.
I found this out here does anyone know if this is the right part from u-joint to hub?
OEM Right Slip Yoke, Dana 50 IFS
Old Nov 1, 2011 | 10:22 PM
cj06's Avatar
cj06
I dont think so , if it is the outer shaft were it engages the locking hub !
this should be the outer that engages the hub ,Dana 50 TTB Outer Axle
Dana 50 TTB rebuild complete.... - Diesel Forum - TheDieselStop.com
Front 3rd member and Dana 50 stub shaft install...(56k warning) - FSB Forums
http://www.therangerstation.com/tech.../d44ttb_hd.GIF
Old Nov 2, 2011 | 09:38 AM
tjc transport
i ain't rite
the part you linked to goes into the differential.
the part CJ06 linked to is the one you want
jmich60
May 2, 2018 01:02 PM
mean green 91
15
Jan 1, 2011 11:50 PM
johnbrnt
Aug 21, 2008 05:35 AM
twiztidfig
Mar 9, 2007 04:28 PM
rrawlins
Offroad & 4x4
Jul 21, 2003 07:54 PM
