Painting steel wheels
Old Apr 11, 2003 | 09:13 AM
KJKozak2's Avatar
KJKozak2
Greetings all,
I have a painting question. I got some of those white steel wagon-wheel rims and they're in pretty bad shape paint-wise. I bought some spray on paint remover and removed all the paint down to the bare metal. I used a small grinder with a wire wheel, too. I'd like to prime and paint them but am having problems with the paint not sticking in spots.
I tried spraying rustolium right onto the metal and there are spots where the paint doesn't stick (as if there were oil on the rim in spots). I also tried primer and the primer just wrinkled up in some spots. As you can tell, I'm no expert.
Any idea why the paint won't stick? Is there some kind of solvent I should wash the rim with before I prime it? Any other suggestions?
Thanks in advance!
Kevin K.
Old Apr 11, 2003 | 09:41 AM
Carlene's Avatar
Carlene
Admom
Hi Kevin -
You might want to read thru these 2 posts.
https://www.ford-trucks.com/forums/s...hreadid=109149
https://www.ford-trucks.com/forums/s...threadid=82781
Old Apr 11, 2003 | 09:58 AM
KJKozak2's Avatar
KJKozak2
Thanks Carlene!
I read those *AFTER* I posted (duh). But which is better, acetone, oil/grease remover, or the muric acid? I have a bottle of the acid that I used to clean my boat hull and can get the acetone or OGR easily.
Also, who makes the epoxy primer? Does Rustolium? I'm hoping all this stuff comes in spray cans as I don't have a pro paint shop.
Thanks again!
K.
Old Apr 11, 2003 | 10:07 AM
Carlene's Avatar
Carlene
Admom
I've used the Rustoleum Primers and Paints in the puff cans when I used to paint our dirt track car and had very good luck with them.
What color are you going with. Reason I'm asking is I painted the wheels on the second dirt car white and used appliance paint. I still "puf canf" primed them first. Also did my fridge and freezer same way. That stuff held up to most everything and the wheels were still shining when we sold the car.
Old Apr 11, 2003 | 10:23 AM
KJKozak2's Avatar
KJKozak2
I'm not sure what color I want. I plan to sell the rims so I may just prime them and sell 'em that way. If I do paint 'em, it'll be black or white. I could use the appliance paint if I go white. Thanks for the idea and the expert advice!
Kevin K.
Old Apr 13, 2003 | 09:16 AM
4starcstms's Avatar
4starcstms
After you stripped the paint did you wash the rims w/ soap and water?
THe paint is probably not sticking due to there being stripper on the metal still. Would be my guess. Ive never tried using acid on the bare metal so I dont know. Sry however when i paint bare metal i clean it with laquer and a scotch pad then wipe dry and pre clean.
smashclash
Paint & Bodywork
Jul 28, 2010 09:55 PM
ghunt
Paint & Bodywork
Mar 22, 2010 07:43 PM
fordman19762003
Paint & Bodywork
Apr 2, 2009 01:19 AM
Green Streak
Paint & Bodywork
May 1, 2005 10:45 AM
Sore Knuckles
Paint & Bodywork
Nov 25, 2003 12:04 PM
