d44 or d50?
Old Jan 1, 2011 | 07:25 PM
mean green 91's Avatar
mean green 91
d44 or d50?
how do i tell the difference? its a ttb and i couldnt find a "50" or "44" stamp on it. the truck is a '90 250 regular cab 4x4 with a 5.8 and a gvwr of 8600lb. it has two leaf springs that look like theyre slung upside down. does any of this suggest a d44 or d50?
i guess the axle specifics on most fords are kind of a mystery due to the fact that so many combos are out there.
Old Jan 1, 2011 | 07:36 PM
Rusty's92's Avatar
Rusty's92
If it has the larger hubs like a dana 60 then it is a dana 50. If it has the small hubs it's a dana 44.
Old Jan 1, 2011 | 07:54 PM
Diesel_Brad's Avatar
Diesel_Brad
What Rusty said.
The D44 hub is approx 3.25"
the D50 and D60 are 4.25"
Old Jan 1, 2011 | 08:17 PM
mean green 91
do i measure at the end of the hub? its tapered from where it comes thru the wheel. it has warn manual hubs. theyre about 3.25 at the end and 4.25 at the widest.
thanks
Old Jan 1, 2011 | 08:21 PM
Rusty's92's Avatar
Rusty's92
Can you upload a picture?
Old Jan 1, 2011 | 08:50 PM
mean green 91
/Users/bradleygriffin/Desktop/photo-1.JPG/Users/bradleygriffin/Desktop/photo.JPG
Old Jan 1, 2011 | 08:52 PM
Diesel_Brad
thanks
At the end of the LOCKING hub.
you have a d44
CJM8515's Avatar
CJM8515
You need to upload it to a image host like tiny pic, imageshack or similar than link it here.
Old Jan 1, 2011 | 08:53 PM
mean green 91
ok that was wrong...ill try to figure out how to post pics
Old Jan 1, 2011 | 09:00 PM
mean green 91
roger. d44.
ive heard a lot of talk about them being sub-par. any truth to that? i havent had a chance to test it much. the motor is shot and im about to swap it. i like to go off road but im not planning on rock crawling or anything like that. its got 3.55 in the rear so i assume its the same in the front. the tires are metric but about 35". itll be a 351 with headers. nothing hi-po.
will the d44 be enough for weekend mud and trails? or is it gonna get shelled with the tall tires?
Old Jan 1, 2011 | 09:58 PM
Rusty's92's Avatar
Rusty's92
A dana 44 is a good axle for some light duty useage. I have had some plow trucks with 44's and never had a problem. With 35's I would think you're pushing it's limits, I wouldn't go any taller. But for some weekend wheeling you should be fine, as long as your u-joints are in good shape.
Old Jan 1, 2011 | 10:15 PM
mean green 91
the passenger side ujoint is shot! i didnt notice it when i bought it and since then i havent been in 4wd. does that whole outside knuckle need to come off to replace the u joint? the yoke itself doesnt look to be messed up.
Old Jan 1, 2011 | 10:29 PM
mean green 91
also, if i want to raise it an inch or two how do i keep the camber plumb?
Old Jan 1, 2011 | 10:33 PM
Rusty's92's Avatar
Rusty's92
The lock out, wheel bearings, hub, rotor, caliper and the spindle need to come off. The passenger side is a two part axle and you'll probably have to cut the clamp on the rubber axle boot up in the beam. If it already hasn't been done. No big deal just replace it with a hose clamp. Then the axle will just slide out. This will give you a good chance to wash, inspect and re-pack your wheel bearings.
Old Jan 1, 2011 | 11:12 PM
mean green 91
are you talking about the u joint closest to the dif? that one is ok. the one out by the hub is the one thats trashed.
thanks for all the input. i appreciate the help
